ASPI or Registry Problem?
Postby dnordquest on Wed Dec 31, 1969 10:25 pm
My new cd-rw is recognized by Windows 98 (in device manager) but when I try to load a burning program, it takes two minutes or more to load and then does not recognize my drive properly. I suspect an Aspi or registry problem, but have replaced the Aspi numerous times without success. Any suggestions?
Thanks!
Dave
Please reply to:omitthis-dnordquest@hotmail.com.
dnordquest
Postby Ian on Wed Dec 31, 1969 10:25 pm
Give us more info.. what OS? What software? Did you run aspichk.exe to see if ASPI is installed and/or working?
Postby dnordquest on Wed Dec 31, 1969 10:27 pm
The OS is Win98 and I have tried both my CD-Maker 2000 and Nero 5.5 programs. The delay between when you click the icon and when the program comes up may be closer to five minutes!! At first I thought the program simply wasn't working. In Nero I get my recorder identified as Image Recorder. The system uses a Celeron 566 soit is not a processor problem.
I attach a log of what happens from Nero:
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/99 1:06:00 PM
Nero Version: 5.5.5.2
Recorder: <Image Recorder> Version: Not Available - HA -1 TA 0 - 5.5.5.2
Adapter driver: <Virtual Device> HA -1
Drive buffer :
CD-ROM: ???
Adapter driver: ???Adapter driver:
CDWRITER IDE1610 (Target 0, G:): Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
BCD E520C (Target 1, H:): Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261636kB)
Free physical memory: 137MB (140424kB)
Memory in use : 32 %
Uncached PFiles: 0x0
Use Inquiry: 1
Wizard: On
CD-Copy
14.12.2001
9:58:07 PM #1 Text 0 File Scsicmd.cpp, Line 1883
SCSI timeout (2), 60000ms, CDB Data[hex]: 12 00 00 00 24 00
9:59:07 PM #2 Text 0 File Scsicmd.cpp, Line 1883
Thanks for any advice you may have!
Dave
dnordquest
Postby Icky on Wed Dec 31, 1969 10:52 pm
It seems to me that Nero and Cdmaker don't support your writer check on
there web sites for a list of supported CD writers.
Icky
