ASUS A7N8X & onboard sound
Postby zak2k2 on Sat Dec 28, 2002 9:36 pm
How does the onboard sound(NVIDIA® SoundStorm) compare to the SB Audigy and or the SB Audigy 2?
zak2k2
Postby Derek on Sun Dec 29, 2002 12:41 am
The Nforce2 onboard sound has pretty decent quality from what I've read. I don't think you'll notice a huge sound difference in your everyday stuff if you use the digital outs.
The main difference is the support for input/output device. The Audigy's will have a lot more in terms of different input and output ports than the onboard Nforce2 sound. In addition, the Audigy 2 has added some new features like DVD-Audio support. If there's a specific feature on the Audigy's specsheet you need, go with that. If you just want good quality sound for everyday stuff, the Nforce2 (thus the ASUS A7N8X) will do well.
Derek
Derek
CD-RW PiMP
Postby zak2k2 on Sun Dec 29, 2002 11:38 am
Thanks for the reply
zak2k2
