craiger wrote:Does a sound card matter for music recordings?
That depends on what you are recording. If you are burning backup copies or compilations of your CDs (where the music has already been digitized) it doesn't matter a whit what sound card, if any, you have installed. The sound card is not used at all for recording source material that is already in a digital format, so its quality never even enters the picture.
On the other hand, if you are recording a copy of a favorite old LP or any other analog source, then the sound card is of utmost importance. You have to use the sound card to digitize the analog music signal in this situation, and the quality of that sound card's analog to digital conversion will be
the most important factor in determining the final quality of your recording (assuming the original analog source is in reasonable shape to begin with).
Depending on how finicky your ears are, you may be satisfied with the 18-bit Turtle Beach Santa Cruz model, the newest 24-bit Sound Blaster Audigy 2 models, or you may want to move up to semi-professional models.
