Audio & Data - What's the difference
Postby mystic77 on Thu Sep 09, 2004 7:35 am
I don't get it, for a CD data disc, if 1 bit goes missing, it's a big deal, the
reliability of the reading is questioned. That's why reading data files is
usually 100% bit for bit reliable.
So what's so hard about reading audio tracks? Why is there software like
EAC? What's so hard about reading bits off an audio track?
mystic77
Postby cfitz on Thu Sep 09, 2004 9:42 am
Data discs have an extra layer of error detection and correction code that audio discs do not have.
Postby hoxlund on Thu Sep 09, 2004 10:42 am
thats why they call him straight shooter cfitz ;)
Corsair Obsidian 800D Case
ASUS P6X58D Premium - LGA 1366 X58 Mobo
Intel Core i7-920 Processor @ 4.2GHz d0 stepping
Corsair 1000HX - 1000Watt Power Supply
G.Skill Ripjaws 12GB DDR3 1600 @ DDR3 2000 - soon to be 24GB
2x XFX HD 5870 XXX Video Card
Postby burninfool on Thu Sep 09, 2004 10:58 am
Data discs usually use mode 1 and can fit 700MB,audio and S/VCD discs use mode 2 and can fit 780MB(80min).A drive reading a mode 2 disc is more saceptable to errors because it doesn't use error correction,that's why copy-protection is more effective on audio CD's.
If you have a CD you can't read use IsoBuster.
Postby mystic77 on Thu Sep 09, 2004 7:13 pm
>Data discs have an extra layer of error detection and correction code that >audio discs do not have.
[-o<
I see, At last somebody who knows! I had been asking around that question for 'bout a year now.
tks!
mystic77
Postby hoxlund on Thu Sep 09, 2004 10:00 pm
you just weren't asking at the right places, and I hope you stay an active member of our wonderful forums
Postby mystic77 on Sun Sep 12, 2004 8:49 am
Does this mean if I listen to the soundtrack of a DVD, it will be of better
quality than from a CD in a player?
mystic77
Postby burninfool on Sun Sep 12, 2004 12:21 pm
mystic77 wrote:Does this mean if I listen to the soundtrack of a DVD, it will be of better
If you are are talking about DVD-AUDIO(96khz/24bit or PCM) then yes,if you are talking about DVD-VIDEO(DTS,AC3) then no.
