Benq 1620 Help
Benq 1620 Help
Postby rail205 on Mon Dec 06, 2004 10:06 pm
I just bought the Benq 1620 DL dvd burner and for some reason I can't get the burnt movies to play on my standalone dvd player.They play fine on my X-box though??? I am using Princo dvd-r 4x media which I have been using with my old LG dvd burner having no problems.
Is it possible that it is burning it as a +r on a -r dvd
Any help would be greatly appreciated.
#-o
rail205
Postby dolphinius_rex on Mon Dec 06, 2004 10:58 pm
you know, the BenQ DW1620 is a great burner.... but that doesn't make it a miracle worker. Please try using some good media on it. Optodisc, Prodisc DVD+Rs, Taiyo Yuden, Ritek.... anyone of those will do.
Postby rail205 on Tue Dec 07, 2004 6:44 am
I understand that I should buy better media, and will these are left over ones. Basically should I buy +R or -R for this burner. I always understood that -R was more compatible with standalone players.
And why would they play in the X-box and not on anything else?
Thanks #-o
rail205
Postby jberry on Tue Dec 07, 2004 10:27 am
use -r....is part of the DVD spec....all players play it....but I would say 99% of players will play +r...I never use +r because I have 2 member sin my family whose players will not play +R (even bitset)....so just easier for me.
jberry
Postby uknown1234 on Tue Dec 07, 2004 11:10 am
try b7s9 firmware, it's said to work better for cheaper media.
uknown1234
