BenQ 1650 DVD+R DL burning speed
Postby apchoo on Sun Feb 19, 2006 5:53 pm
I recently upgraded my dvd burner from a Pioneer 108 to a BenQ 1650. My reason for upgrading was purely because I wanted a faster DVD+R DL burner. My initial choice was the BenQ 1640 after reading the CDRLabs review (I use Verbatim 2.4X +R DL MKM-001 which the 1640 can supposedly burn at 8X), but saw the release of the 1650, and after reading up as much as I could on this new drive, decided to go for it as it was supposedly similar to the 1640. I immediately upgraded my 1650 to the latest BCDC firmware.
I've burnt a few 8X -R/+R SL media and the drive performed flawlessly. As this is my first BenQ burner, I love the ability to change the book type.
However, I burnt my first +R DL disc last night using a Verbatim 2.4X MKM-001 disc. I was surprised it burnt at 2.4X. The 1640 supposedly could burn at 8X. Can anyone confirm this is the case with their 1650/1655? My Pioneer 108 could burn the Verbatim at 4X so this is a step backwards for me! Should I have gone for the 1640 instead? Or should I wait for a new firmware release that would enable me to burn MKM-001 media at faster than 4X?
apchoo
Postby Ian on Sun Feb 19, 2006 5:54 pm
Yeah.. that's one down side of the DW1655. If you want to burn at 8x you will need 8x DVD+R DL media.
Postby dolphinius_rex on Sun Feb 19, 2006 10:32 pm
The BenQ DW1650/DW1655 models don't support MKM001 at 8x anymore because they couldn't make it work properly on a consistant basis. Some drives do ok, but not all. Verbatim also does not recommend burning MKM001 at 8x, they claim a 6x maximum and only with some drives.
Re: BenQ 1650 DVD+R DL burning speed
Postby thegdog on Mon Feb 20, 2006 6:36 pm
apchoo wrote:However, I burnt my first +R DL disc last night using a Verbatim 2.4X MKM-001 disc. I was surprised it burnt at 2.4X. The 1640 supposedly could burn at 8X. Can anyone confirm this is the case with their 1650/1655? My Pioneer 108 could burn the Verbatim at 4X so this is a step backwards for me! Should I have gone for the 1640 instead? Or should I wait for a new firmware release that would enable me to burn MKM-001 media at faster than 4X?
The 1650/1655 drives are limited to 2.4x for MKM-001. They both will burn the newer MKM-003 at 8x, however.
What you can do, though technically it voids your warranty, is run the firmware through MediaCodeSpeedEdit, where you can change the MKM-001 media to write at 8x. You can download it from their website:
http://ala42.cdfreaks.com/MCSE/
Of course, your mileage may vary. Some MKM-001 media will not do as well at 8x than others will. I've had some that have scanned quite poorly, whereas others were fantastic.
thegdog
Postby apchoo on Wed Feb 22, 2006 6:16 pm
Thanks for all the replies. I managed to swap my 1650 for a 1640 :P . I've yet to burn an MKM-001 disc in 8X but the option is there (upgraded the firmware to latest BSOB). I'll experiment between 4X and 8X and see if I have any probs on my 3 dvd players (Harman Kardon, Sony & Shinco). I had no probs reading MKM-001 discs burnt at 4X on my Pioneer 108.
apchoo
