Burning CD/CD-RW on lower speed
Postby trolko on Wed May 18, 2005 2:34 am
Hi,
I need burn some CD/CD-RW on lower speed with Nero Burning ROM. Is there any way/solution to do this ??
For example : I need backup my original CD-AUDIO and burn it with 4x, but nero minimum speed is 8x.
thanks
trolko
Postby dodecahedron on Wed May 18, 2005 2:54 am
the minimum burning speed is a property of the drive, not of Nero.
if the drive's minimum speed is 8x then you won't be able to burn it at a lower speed with any other app.
