CD-RW Burning Problem T_T
Postby Bloodex on Wed Jul 20, 2005 11:09 pm
Hi, im currently using a Sony CD-RW CRX230ED. I've been using this to burn my media in data format for a few months now onto an Ridata 700MB CD-R without any problems. Lately however, I find that sometimes when I put in either a blank or burned Ridata CD-R, my burner cannot detect it. When i keep taking it out and putting it back in, it sometimes works. And when i try to burn it works maybe one tenth of the time and fails the rest. These burned Ridata CD-Rs run fine on the regular CD-ROM. I do not know what I can do to solve the problem.
I'm currently using Nero 6.
Below, i am Pasting the Error Log.
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=30208 bytes, created 6/11/1997 8:01:02 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 9:18:06 PM
Nero version: 6.3.1.18 (Nero Express)
Recorder: <SONY CD-RW CRX230ED> Version: 4YS1 - HA 0 TA 1 - 6.3.1.18
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
CD-ROM: <CREATIVE CD5233E-CF >Version: 1.04 - HA 1 TA 0 - 6.3.1.18
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6E040L0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY CD-RW CRX230ED atapi Port 0 ID 1 DMA: On
CdRomPeripheral : CREATIVE CD5233E-CF atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic STEALTH DVD st3wolf Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY CD-RW CRX230ED G: CDRom0
CREATIVE CD5233E-CF E: CDRom1
Generic STEALTH DVD F: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 125MB (128696kB)
Memory in use : 75 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
20.7.2005
CD-ROM (ISO)
3:10:04 PM #1 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
3:10:04 PM #2 Phase 94 File dlgbrnst.cpp, Line 1845
Power-Burn activated
3:10:04 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
3:10:04 PM #4 Text 0 File Writer.cpp, Line 124
Writer SONY CD-RW CRX230ED running
3:10:04 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3899
3:10:04 PM #6 Text 0 File Burncd.cpp, Line 3172
Turn on Track-at-once, using CD-R/RW media
3:10:04 PM #7 Text 0 File DlgWaitCD.cpp, Line 246
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 296210 ( 65:51.35)
3:10:04 PM #8 Text 0 File DlgWaitCD.cpp, Line 258
3:10:04 PM #9 Text 0 File DlgWaitCD.cpp, Line 2143
Recorder: SONY CD-RW CRX230ED;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
3:10:04 PM #10 Text 0 File DlgWaitCD.cpp, Line 419
3:10:04 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
original disc pos #0 + 296211 (296211) = #296211/65:49.36
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 296209 blocks [SONY CD-RW CRX230ED ]
3:10:04 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [SONY CD-RW CRX230ED ] for write in TAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 606947328, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
296211 | lead-out | 1 | 0x00 | 0x41
3:10:04 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1030
Removed 2 run-out blocks from end of track 1. Length: 296211 -> 296209.
3:10:04 PM #14 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
3:10:04 PM #15 Text 0 File Burncd.cpp, Line 4182
Cache writing successful.
3:10:04 PM #16 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
3:10:04 PM #17 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 40x (6,000 KB/s)
3:10:04 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2344
3:10:04 PM #19 Text 0 File Mmc.cpp, Line 20453
Set BUFE: Power-Burn -> ON , SMART-BURN : ON
3:13:27 PM #20 Text 0 File ThreadedTransfer.cpp, Line 229
3:16:40 PM #21 SCSI -1135 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 0, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
3:16:41 PM #22 CDR -1135 File ThreadedTransferInterface.cpp, Line 1830
Write error
3:16:41 PM #23 TRANSFER -18 File ThreadedTransferInterface.cpp, Line 1830
Could not perform EndTrack
3:16:41 PM #24 Text 0 File Mmc.cpp, Line 15278
<SONY CD-RW CRX230ED > start Close Session
3:18:56 PM #25 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
3:18:56 PM #26 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 40x (6,000 KB/s)
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=7.1.0.188 , size=44288 bytes, created 11/10/2004 6:27:34 PM
File 'Drivers\CDRALW2K.SYS': Ver=7.1.0.188 , size=24832 bytes, created 11/10/2004 6:30:18 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 12/20/2004 2:37:14 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=4, 2, 12, 0, size=91136 bytes, created 6/4/2004 2:36:50 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 2, 12, 0, size=28544 bytes, created 6/4/2004 2:37:30 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 2, 12, 0, size=5760 bytes, created 6/4/2004 2:40:42 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/19/2003 3:05:04 PM (Adapter driver for rec)
Registry Keys:
Bloodex
Postby dodecahedron on Thu Jul 21, 2005 1:00 am
try using other media. Taiyo Yuden if you can get it. seems to be a media problem.
other things to check/try:
what's this?
is this some kind of virtual CD drive?
if so, disable/uninstall it, that might help.
burn in Disc-at-once, not Track-at-once (unless you're doing Multisession - not recommended!)
what software do you have installed ? it looks like you have (or had) InCD and Roxio DragToDisc/DirectCD.
first it is bad to have both installed simultaneously. in any case unless you must have packet-writing software, i recommend you uninstall it (both). you might also need registry cleaning utilities (Nero InCD registry cleaner, Roxio Zap).
