cdrw and dvd rom on same ide cable
Postby mrk1283 on Wed Dec 11, 2002 4:51 am
i have an lg8160b and as i am after a new dvd drive i would like to have both on the same ide as i dont want to slow my primary down as my hd is ata133 and i have a non raid mobo. was wondering wether the drive i am after (lite-on 166s) will conflict in any way with the lg drive? anyone got these simular seyup at all?
I plan on making dvd the sec master and cdrw the sec slave
running xp pro sp1 and 100% stable and error free
mrk1283
I'm OK
Postby nosro on Wed Dec 11, 2002 6:16 am
I use CD-RW on master and DVD-ROM on slave, both on the same IDE. I do 48x CD copies from the DVD-ROM to the CD-RW with no problems. I've recorded at 48x while watching a movie and have no problems.
I use an Athlon XP 1800+ on VIA KT266a running Windows 2k
nosro
Postby mrk1283 on Wed Dec 11, 2002 6:27 am
Excellent stuff, what I needed to hear, I'll order me lite-on as soon as i deposit my card amount :)
mrk1283
Postby BuddhaTB on Wed Dec 11, 2002 11:31 am
I have my Pioneer DVD-Rom hooked up as secondary master and my TDK 48x CD-RW drive hooked up as secondary slave. This configuration works well for me, but doing direct CD copies on the fly does slow down the write speed of the CD-R and tops off at around 30x.
If you planning on doing a lot of direct CD copies on the fly, then I would suggest you placing the DVD and CD-RW drive on separate IDE cables. This will help increase the data transfer and write speed when doing direct CD copies on the fly. If your not doing a lot of this, then the DVD and CD burner on the same IDE cable is okay. Also, it doesn't matter if the DVD or CD-RW drive is the master or slave on the secondary IDE channel, just try it one way and if that doesn't work, then try setting the jumpers in the opposite way.
BuddhaTB
Re: I'm OK
Postby voltron on Wed Dec 11, 2002 6:20 pm
nosro wrote:I use CD-RW on master and DVD-ROM on slave, both on the same IDE. I do 48x CD copies from the DVD-ROM to the CD-RW with no problems. I've recorded at 48x while watching a movie and have no problems.
Which DVD-ROM drive has a sustained transfer rate of 48x?
I could believe 16x on the fly cd copies, but 48x?
voltron
