difference between dvd-r general purpose & authoring?
Postby msuiter on Thu Jul 03, 2003 11:02 pm
i've seen this on several media sites. anyone know what the difference is and when to use each?
--Bubba
box:
athlon xp 2000, 1gb pc2100, abit kr7a-133, nvidia ti4600 dual-dvi, maxtor 120GB & 80GB, sb audigy, linksys lne100tx nic, asus 16x dvd, tdk 24/10/40x cdrw, viewsonic vg191 & vg151 lcd displays, windows xp pro
msuiter
Postby dolphinius_rex on Fri Jul 04, 2003 12:56 am
I don't remember the specifics, but DVD for authoring uses a different laser frequency, so it is incompatible with any other format of recordable DVD, even DVD-R for general use. Physically speaking the DVD-R for authoring is closer to a DVD+R then a DVD-R for general use, becasue unlike the DVD-R for general use, it does not have a portion of the disc pre-burned. This allows both DVD+R and DVD-R for authoring to be much more likely to work for making backups of new copyprotected DVDs. Of course DVD-R for authoring is not supported anymore by anyone as far as I've seen, which is probably good because things are confusing enough.
Does that help?
Postby Justin42 on Fri Jul 04, 2003 1:55 am
Isn't DVD-R For Authoring just that, what people who are actually mastering discs able to use? It has no pre-burned region lock or "disc type" info on it (the DVD-R for General is region free automatically, no way around it)..
I think it is more a way to force the big entertainment companies to pay more than anything. I think it's pretty much identical to DVD-R for General except for the laser frequency issue, otherwise (phyiscal structure of the data on the disc)
It's still used; look around for media on the web, it's expensive, and finding a burner that supports it is REALLY ridiculous. (I looked into buying one once figuring it'd give me more freedom in what I burned.. then I saw the cost and forgot that idea.)
Postby dolphinius_rex on Fri Jul 04, 2003 2:51 am
DVD+R offers all the same advantages, but doens't use the same laser frequency. So just buy a dual format drive and you can keep the DVD+R media for authoring and the DVD-R media for archiving (since it's cheaper).
Postby jase on Wed Jul 09, 2003 6:16 am
Really?
My work colleague sent some +Rs out for professional (stamped) duplication for a piece of software developed in-house -- the duplicators flatly refused it. The ONLY format they would accept was DVD-R authoring. The drives for these cost around $2000.
That wasn't just one company either -- 4 out of the 5 refused the +R disc. +R is a consumer standard, as is -R general purpose.
jase
Postby dolphinius_rex on Wed Jul 09, 2003 11:31 am
I know a place that will do it with anything other then DVD-RAM, but they are here in Canada (B.C. to be a little more exact).
