DMA problems in WinXP
Postby lanker on Mon Oct 24, 2005 9:20 pm
On this system AMD300+ 1GB Ram, HDD 120GB etc, etc I had to invalidate XP failback 6 error counter under HKEY_LOCAL_Machine Bla Bla MasterIDDataChecksum and SlaveDataChechsum. reboot released PIO mode to DMA but still can't get to DMA66 for max data transfer for this Plextor 716a burner. Checked Bios and config Secondary IDE for DMA 5 or 6 . Have yet to try in Bios User defined bla bla bla. Any insite from any one. Oh board is A7V8X-X W/ Via kt400 chipset. The above item deffers with an intel chipset
____________________________
moved to DVD Recordable forum.
please do not post requests for help in the FAQ.
lanker
Postby dodecahedron on Fri Oct 28, 2005 7:39 am
lanker, can you say exactly what registry key that is ?
Postby dodecahedron on Fri Oct 28, 2005 7:40 am
what DMA mode is the drive in?
have you updated the latest VIA drivers ?
Postby lanker on Sat Oct 29, 2005 5:13 pm
New to this Forum. Reg key is; HKEY_LOCAL_Machine\System\CurrentControlSet\Control\Class\(4D36E96A-E325-11CE-BFC1-08002BE10318)
Clicking key brings up both IDE Channels listed as-0000, 0001,0002,Properties. Also, while I was able to reset the 6 error failback by deleating MasterIDChecksum and SlaveDataChecksum under under IDE Channel 2 Master/slave and release this system from the locked PIO mode under DMA settings,was able to set DMA Mode 2. The burner supports UDMA66. So thats were I'am at. I also disconnected my zip drive from IDE 2 as slave. Bios is Award V6.0, Revision 1012 dated 7-22-04. I never did check the chipset drivers as it was a new XP Pro install, though headded that way as soon as I post this
lanker
Postby lanker on Sat Oct 29, 2005 7:19 pm
Yes checked via driver appears to be5.04A
lanker
Postby lanker on Sat Oct 29, 2005 8:36 pm
Just found this. MS Help and support Article ID: 817472 Revision 7.4 dated about two weeks ago :o
lanker
Postby ala42 on Sat Oct 29, 2005 9:20 pm
Do you use an 80 wire cable ?
ala42
Postby lanker on Sun Oct 30, 2005 1:23 pm
Of course. What I did this morning was back to Regedit and deleated MasterIDChecksum. Then to bios and rechecked all and in between trying other config, removed IDE Channel 2 each time I rebooted. Finally was able to obtain UDMA-4
lanker
