DVD Burner problem?
DVD Burner problem?
Postby darkwarrior on Thu Jan 06, 2005 9:11 am
Ok, I need some serious help here sadly.
This morning I tried burning a dvd, simple work, stick in writer, backup, burn. Worked perfectly except the DVD skipped. I learnt this was down to a scratched DVD.
However attempts since then of different dvds have all resulted in a nice DVD coaster because I keep getting some kind of error while burning. THe backup files are fine, I've tested them on the computer, the source dvd is fine and like I said, I've used different DVDs but is getting different errors under different software.
DVD Shrink says it can't write the lead-out.
Nero had some data error problem.
DVD shrink had the one below, the only one I've been able to save.
I don't know what it is and I haven't changed anything. Normally its such a simple process so I don;'t know what going wrong :(
Any help is appreciated
I am using Infiniti Samurai DVDs. Also, even though it will read these discs, if I put a blank in, it recognises the disc is there but gives no details on its storage capacity, it just says 0 space free 0 space used.
My DVD drive is DVDRW LDW-851S Firmware version G508
I don't know if this will helpb ut just tried again with DVD Shrink and got this.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/2003 14:25:04
Nero API version: 6.0.0.11
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <LITE-ON DVDRW LDW-851S> Version: GS08 - HA 1 TA 1 - 6.0.0.11
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
DiskPeripheral : ST3120023A atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y160P0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : MITSUMI CR-48XCTE atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW LDW-851S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 1 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 291MB (298400kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
6.1.2005
NeroAPI
03:43:09 #1 Phase 112 File APIProgress.cpp, Line 235
DVD-Video files reallocation started
03:43:09 #2 Phase 114 File APIProgress.cpp, Line 235
DVD-Video files reallocation completed (no file modified)
03:43:09 #3 Phase 111 File APIProgress.cpp, Line 235
DVD-Video files sorted
03:43:10 #4 Text 0 File Reader.cpp, Line 118
Reader running
03:43:10 #5 Text 0 File Writer.cpp, Line 127
Writer LITE-ON DVDRW LDW-851S running
03:43:10 #6 ISO9660GEN -11 File geniso.cpp, Line 3854
03:43:10 #7 ISO9660GEN -11 File geniso.cpp, Line 3854
03:43:10 #8 Text 0 File Burncd.cpp, Line 3173
03:45:43 #9 Text 0 File DlgWaitCD.cpp, Line 228
Last possible write address on media: 2297887 (510:38.37)
Last address to be written: 2286114 (508:01.39)
03:45:43 #10 Text 0 File DlgWaitCD.cpp, Line 233
03:45:43 #11 Text 0 File DlgWaitCD.cpp, Line 1722
Recorder: LITE-ON DVDRW LDW-851S, Media type: DVD-R
Disc Manufacturer: SONY04 - D1
03:45:43 #12 Text 0 File ThreadedTransferInterface.cpp, Line 768
original disc pos #0 + 2286115 (2286115) = #2286115/508:1.40
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286115 blocks [LITE-ON DVDRW LDW-851S ]
03:45:43 #13 Text 0 File ThreadedTransferInterface.cpp, Line 937
Prepare recorder [LITE-ON DVDRW LDW-851S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4682270720, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286115 | lead-out | 1 | 0x00 | 0x41
03:45:43 #14 Phase 24 File APIProgress.cpp, Line 235
Caching of files started
03:45:43 #15 Phase 25 File APIProgress.cpp, Line 235
Caching of files completed
03:45:43 #16 Phase 36 File APIProgress.cpp, Line 235
Burn process started at 4x (5,520 KB/s)
03:45:43 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2130
03:45:43 #18 Text 0 File DVDR.cpp, Line 1485
Recording mode: Sequential Recording Mode
03:45:43 #19 Text 0 File Mmc.cpp, Line 18878
Set BUFE: supported -> ON , Generic write control : ON
03:45:43 #20 Text 0 File DVDR.cpp, Line 1600
Start write address at LBA 0
03:45:43 #21 Text 0 File Cdrdrv.cpp, Line 7906
Book Type: DVD-R (2), Part Version: 5
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
03:45:53 #22 Text 0 File Writer.cpp, Line 318
03:45:53.171 - LITE-ON DVDRW LDW-851S : Queue again later (Intervall : 11msec)
03:50:47 #23 SCSI -1135 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x01430000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x0B 0x0B 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
03:50:47 #24 CDR -1135 File Writer.cpp, Line 335
Write error
03:50:48 #25 Text 0 File ThreadedTransfer.cpp, Line 227
03:50:49 #26 Text 0 File ThreadedTransfer.cpp, Line 221
03:50:49 #27 Phase 38 File APIProgress.cpp, Line 235
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.0.0.171 , size=24839 bytes, created 13/01/2003 09:19:26
File 'WNASPINT.DLL': Ver=V1.20, size=57344 bytes, created 04/02/2003 08:24:08
File 'Drivers\Tpp200.sys': Ver=5.04.1150.0 , size=35541 bytes, created 05/10/2001 12:54:28
File 'Drivers\Tpp300.sys': Ver=5.04.1150.0 , size=33669 bytes, created 05/10/2001 12:54:28
File 'Drivers\Tpp725.sys': Ver=5.04.1150.0 , size=43269 bytes, created 05/10/2001 12:54:28
Registry Keys:
darkwarrior
Postby spryfly on Sat Jan 08, 2005 12:16 pm
try different media....
"Why? Said the spry little fly."
Nec 3500 LD V2 B6 Quiet
Benq 1620 B7T9 Stock
Liteon 1633sx BS41 Patched for 12x DL Ripping
spryfly
