DVD Ripping Problems!
How fast is too fast?
Postby gigabyte on Fri Dec 12, 2003 7:14 pm
Hello everyone.
I am currently experiencing problems with ripping DVD's and if you could help me, I would be very grateful.
Here's the situation: I pop my Spiderman Disk 1 DVD into my dvd rom.
It reads it fine and I can open it in PowerDvd to watch it.
I open DVD Shrink and I click back-up and do a full rip. I then rip the DVD onto my harddrive.
When I try to open the files from my harddrive using DVD Shrink, I get a region error.
I fix it using Ifoe edit and I open it again. It loads to the menu.
I click scene selection and I select a screen. The DVD restarts from the beginning.
I try to play a different scence, same result. When I try to just play the DVD, it still restarts itself!
What is going on? Am I doing something wrong??? Please help!
gigabyte
Postby aviationwiz on Fri Dec 12, 2003 7:18 pm
What region error are you getting in DVD Shrink?
Does it look like this?
If so, just hit OK when it is on Region 1, or change the region selected to whatever region the DVD is.
Postby gigabyte on Fri Dec 12, 2003 7:21 pm
Wow, fast responses!
Sorry, my bad. I meant when I open it with WinDVD, it doesn't open. I then try opening it with PowerDVD, and it keeps resetting
gigabyte
Postby gigabyte on Fri Dec 12, 2003 7:22 pm
how do you open ripped dvds on your harddrive using WinDVD?
gigabyte
Postby aviationwiz on Fri Dec 12, 2003 7:24 pm
I'm not sure how to open a DVD from the HDD in Win DVD. When you try opening it in Power DVD, you are going to the source button and hitting "Open DVD from Hard Drive" or whatever that option is, right? Then you just select the folder from there.
Postby gigabyte on Fri Dec 12, 2003 7:25 pm
i do, but then when i try playing the movie from the main menu, it keeps on restarting! It wont play the movie, it just keeps resetting it :evil:
gigabyte
Postby aviationwiz on Fri Dec 12, 2003 7:30 pm
Can you post a picture of the error you are getting when you try opening the before IFO Edited DVD in Power DVD? If you don't have a place to put it, you can email it to me here: aviationwizard@msn.com
Postby gigabyte on Fri Dec 12, 2003 7:42 pm
I sent you an email with the picture
gigabyte
Postby NoSmartz on Fri Dec 12, 2003 8:03 pm
You open up a rip't movie from the HD by right clicking on the windvd screen when it's open and choose"playlist".From there,an explorer window should appear and you just find the flick you rip't and add all the rip't files to the window and hit "open".
That's it.
E
NoSmartz
Postby aviationwiz on Fri Dec 12, 2003 8:08 pm
Here's the error:
Postby NoSmartz on Fri Dec 12, 2003 8:43 pm
I thought windvd was what was being used.
NoSmartz
Postby gigabyte on Sat Dec 13, 2003 12:48 pm
I tried using WinDVD but i didnt know how to open up ripped files, so i trieed powerDVD, but it keeps on restarting when i click something on the menu of the dvd (such as scene selection)
gigabyte
Postby NoSmartz on Sat Dec 13, 2003 12:58 pm
If you haven't uninstalled WinDVD try what I talked about a few posts back(rightclick on windvd window,playlist).What happens?
NoSmartz
Postby gigabyte on Sat Dec 13, 2003 12:59 pm
Hooray, it finally works!
Thanks alot for all of your help!
gigabyte
Postby NoSmartz on Sat Dec 13, 2003 1:23 pm
excellent.
E
NoSmartz
