DVD Shrink problem
DVD Shrink problem
Postby keri on Fri Sep 24, 2004 7:00 am
I am trying to use DVDShrink to compress a DVD that i have already ripped with DVD Encrypter, but DVDShrink keeps failing.
It claims to have run out of memory, which i thought was strange as i have over 20Gb free on my primary drive, but then i ran some system tools when compressing the DVD and i noticed it was actually using my RAM, and in no time at all it used 1.9Gb of RAM then it dies.
I am using the latest DVD Shrink as i only downloaded it yesterday.
Can anyone help me out with this ?
Keri.
keri
Postby keri on Fri Sep 24, 2004 7:42 am
Just to add some more details, the spec of my PC is
P4-3.2Ghz
1Gb RAM
XP Pro with SP2
Pioneer 108 DVDR
Keri.
keri
Postby keri on Fri Sep 24, 2004 8:03 am
Ok sorted it, quick downgrade to 3.1.7 Beta and job is done :)
Keri.
keri
Postby hoxlund on Sat Sep 25, 2004 7:20 pm
what firmware is that dvr-108 btw, just curious
Postby keri on Sun Sep 26, 2004 9:02 am
hoxlund wrote:what firmware is that dvr-108 btw, just curious
To be honest i have no idea, what is the easiest way of finding that out, and how do i update it as odds on an update will be required.
Thanks,
Keri.
keri
