Firmware Question
Firmware Question
Postby elpipetuanis on Sat Jul 19, 2003 9:49 am
I have a Lite-on cd Burner. First it was a 48x24x48 then i learned here that i could upgrade the firmware to the 52x24x52. So i did that. Now i am wondering if I can update the firmware to the new 52x32x52. Is that possible?
¿Quien es el Pipe Tuanis?
elpipetuanis
Postby Prowler on Sat Jul 19, 2003 10:13 am
Not at the moment. The 52x32x52x uses a Mediatek series 7 chipset. Your's uses a series 6. Trying to flash it with series 7 firmware will most likely leave the drive inoperable.
Prowler
Postby CDRecorder on Sat Jul 19, 2003 11:15 am
I think that people have tried to flash a 6 series drive with the firmware of a 7 series drive, and it has always failed.
Postby elpipetuanis on Sat Jul 19, 2003 4:29 pm
thanks that is what i thought but just wanted to make sure.
elpipetuanis
Postby CDRecorder on Sun Jul 20, 2003 1:23 am
You're welcome. :D
