First Attempt - Make It Work :)
Postby iKwak on Fri Sep 03, 2004 7:23 am
I read many guidelines and tutorial on several board.
1) I've downloaded both DVD Shrink 3.2 and DVD Decrypter 3.5.1.0.
2) I used DVD Shrink to backup (encode?) only the main movie into an ISO format. Came out to be 4.45GB.
3) Using DVD Shrink, I press Backup.
Target Device
I've selected "ISO Image File and burn with DVD Decrypter
Under Select target image file, I've selected the DVD-rw drive.
edit: The burning started, as it seems. When the burning was done, I took the dvd-r to my dvd player and nothing comes up. I brought it back to my pc, and no data or any info is showing up when looking at the property.
What am I doing wrong?
iKwak
Postby Spazmogen on Fri Sep 03, 2004 9:33 am
Are you sure that 'simulation' is not checked off when you burn ?
I use a similar process: DVD Decryptor & DVD2ONE.
I decrypt to ISO, then extract the main movie with DVD2ONE in file mode.
Burn the DVD in Nero as DVD Movie. Just drag the files over to the video folder. Ignore the audio folder in Nero.
