HELP HOOKING UP SPEAKERS
Postby gigabyte on Sun Jan 04, 2004 12:42 am
hello everyone,
i just got the logitech z-540 speakers but i need some help hooking them up :oops:
it says that i have to connect the green plug from the audio input cable to the front jack and the black plug into the rear jack into your soundcard.
if i plug the black plug into the back, where does the green one go???
help! :-?
gigabyte
Postby David on Sun Jan 04, 2004 1:56 am
The z-540's are ment for quad channel sound cards since you didn't mention your sound card model i'll asume your sound card is.
The green plug should be pluged into the front channel audio out port.
The black plug should be plug into the rear channel audio out port.
David
Postby gigabyte on Sun Jan 04, 2004 1:58 am
i dont believe i have a 4 channel sound card (Doh! :o ) where can i check my current one anyways?
gigabyte
Postby Turkeyscore.com on Wed Jan 07, 2004 1:55 am
what motherboard do you have? It might have 4-5 channel support. if not, you can get a surround sound card for about $30
zzzt *pop*
Turkeyscore.com
