help with front usb 2.0 connections in case
Postby kaga on Thu Oct 16, 2003 10:26 pm
i just bought a Lian-Li PC-7B USB, 12-Bay, Aluminum Cases. Color: Black. from newegg
i just finish connetting the front usb 2.0 ports i don't know if i plug the stuff correctly becaue i tried with my mose and is not picking up anything.
does it only worth with usb 2.0 products or can u use it with 1.0 products?
Coming Soon Sager NP2090
Intel® Core™2 Duo T7500 2.2GHz
nVIDIA GeForce 8600 GT w/512MB
2GB DDR2/667 Dual Channel Memory
100GB SATA/150 7,200 RPM
Dell Inspiron 6000
kaga
Postby Stoner on Thu Oct 16, 2003 10:34 pm
USB 2.0 is backward compatible w/ ALL USB devices. The problem is either 1) you didn't install the proper USB 2.0 driver, or 2) you didn't hookup the USB 2.0 connector to the correct socket on the mobo.
Stoner
Postby kaga on Thu Oct 16, 2003 10:46 pm
i got the lasest update for my mobo and drivers probaly didn't plug it in right.
can any one tell how me how to plug it in??
my mobo is an asus av7333
the case plugs are in the followin order
sheild, vcc1, data-1, data+1 ,gnd1
and vcc2, data-2, data+2, gnd2,
and my mobo plugs for the usb are
nc, gnd,ldp1, ldm1, usb+5v
and gnd, ldp2, ldm2 ,usb+5v
Dell Inspiron 6000
kaga
Postby David on Thu Oct 16, 2003 11:22 pm
To me it looks like case plugs match up the following way.
First mobo row
sheild = nc
gnd1 = gnd
data+1 = ldp1
data-1 = ldm1
vcc1 = usb+5v
Second mobo row
gnd2 = gnd
data+2 = ldp2
data-2 = ldm2
vcc2 = usb+5v
David
Postby kaga on Fri Oct 17, 2003 12:15 am
thx dude its working now
Dell Inspiron 6000
kaga
