Help with Install of EasyCD Creator 5 Platinum on Win XP Pro
Postby Zoetrop on Mon Dec 02, 2002 10:49 pm
When I try to Install it gives me alot of error's about the registry and also says drive not supported. Then when I try to run it shows on the tasks bar, but won't come up on the desktop, it does not show in add remove programs so I can not delete it.
Please any help at all?
Zoetrop
Postby sonyman on Mon Dec 02, 2002 11:02 pm
Have you followed the instructions on Roxio's site for installing on XP?
There are some updates you need to install in a specific order. I don't know it off hand since I don't use Roxio crap. ;-)
-Scott
Gigabyte GA-8KNXP
Intel Pentium 4 3GHz
1024MB PC3700 DDR @400MHz CL2
ATI Radeon 9700 Pro
Sony DRU-500A
Lite-On LTR-52327S 52x32x52
sonyman
Postby Zoetrop on Mon Dec 02, 2002 11:37 pm
Thankyou for youy reply.
Zoetrop
check my post
Postby modemfreak on Wed Dec 04, 2002 5:06 pm
http://www.cdrlabs.com/phpBB/viewtopic.php?t=7273
ask me if you have questions with regard to that.
Dave
modemfreak
