XP Home and hyperthreading?
Postby Turkeyscore.com on Sat Dec 13, 2003 3:44 am
Does Hyperthreading work with XP home? If so, why go with pro, If not, why do they sell it with Hyperthreading PCs in stores?
zzzt *pop*
Turkeyscore.com
Postby BurninMan921 on Sat Dec 13, 2003 11:41 am
Yup, it works with Home. Pro supports two "real" CPU's (as opposed to Hypertheading's two virtual CPU's), but other than that I'm not sure that the Pro vs. Home differances are (I use Win2K, not XP)...
BurninMan921
Postby CDRecorder on Sat Dec 13, 2003 4:08 pm
Pro does have a few more features than Home does, but not that many more. I'm not sure what all of the differences are, but one difference I've run across recently is that Pro allows you to password-protect folders that are shared on the network, and Home doesn't. I particularly noticed it because I'm running Home on my XP boxes because it's cheaper.
Postby UALOneKPlus on Sun Dec 14, 2003 8:12 am
-Danny Kaye
UALOneKPlus
