In House Review - BenQ DW1620 Double Layer 16x DVD±RW
Postby cfitz on Thu Feb 24, 2005 2:37 pm
dolphinius_rex wrote:So far, it looks very similar to my Plextor PX-712a for scan results on good media, but on very bad media it tends to have differing opinions... but that could be because of differences in error tolerances.
Thanks dolphinius_rex. I guess it would be safe to say that is genuinely measuring C1/C2 errors, but that, as with all C1/C2/PI/PO measurements, the numbers you get are a function of the writer, reader and disc and will vary from what you measure elsewhere. I didn't expect absolute matches, but I did want someone else to confirm that what I was concluding was reasonable, and I believe that is what you have done.
Thanks again. I know you are busy.
Postby dolphinius_rex on Thu Feb 24, 2005 4:52 pm
It wouldn't be my first choice for a CD tester... but I wouldn't have a problem accepting the data from its' tests either :wink: ...well, that's how I feel for the moment. I reserve the right to change my mind with future further testing of course :D
