InCD won't work
InCD won't work
Postby tibpol on Mon Dec 23, 2002 6:10 pm
Hi everyone
I have ARTEC WRR-4848 installed on my computer.
NERO software came with it.
I installed InCD updated to v.3.51.91
I can't format any CDRW.
Formatting starts and about 58% it stops and an error massage pops up:
"Error Code:
0051-0003-000c-0000"
Thank you for the help
tibpol
tibpol
Postby Inertia on Mon Dec 23, 2002 7:45 pm
Ah yes, the old "0051-0003-000c-0000" error that we know so well. :-? :-?
Seriously, cryptic error codes like this are generally useless for pointing to any underlying problem.
Have you tried a different brand of high quality CD-RW media? The problem could be caused by low quality or mismatched media. Some burners are picky about which media will meet their requirements.
Inertia
Postby tibpol on Mon Dec 23, 2002 8:15 pm
Thank you Inertia,
I'm trying to format a brand new
MEMOREX CD-RW 700MB
4X MULTI SPEED
I had the same results with MAXELL and SONY
tibpol
tibpol
InCD problems
Postby freemanzhu on Mon Dec 23, 2002 11:36 pm
I actually just posted a topic a few days ago on problems with InCD (Explorer crashes during writing, among other things). The latest version of Roxio's DirectCD (provided with Easy CD Creator) works much better, provided you patch it to 5.3.2 (there's a major bug under Windows XP SP1 in 5.2 and earlier). Really though, none of the packet-writing programs is all that great reliability-wise; I'm really looking forward to the day when Windows has built-in support for packet writing via Mt. Rainer.
freemanzhu
Postby tibpol on Tue Dec 24, 2002 4:10 pm
I finally got it work.
If you have the same problem try this.
Go out and buy,
"SONY 650MB CD-RW650HS
For
HIGH SPEED DRIVE only
4X - 10X "
Very fest no problem at all.
The formatting takes about ten minutes
I've formated two CD's in no time.
tibpol
tibpol
