LITE ON LVW-5001 SIGNAL HELP!
Postby capcom_allstar on Mon Jan 10, 2005 3:08 pm
hi guys im new to the forums and need this problem solved
i have a lite on lvw 5001 dvd recorder
i am trying to record from video to dvd
i have a pal dvd recorder and a pal sony video player
the tape i am trying to tape onto dvd is a ntsc tape but my sony video player plays ntsc videos fine..the video plays fine through the televsion and if i run it though the lite on dvd recorder.
but when i go to record it to dvd it wont let me as it says "Wrong Signal Type"
is there any way around this problem?
capcom_allstar
Postby capcom_allstar on Mon Jan 10, 2005 6:26 pm
also i have tried a ntsc to pal signal converter and that dont work either
can someone solve this? :D
capcom_allstar
Postby capcom_allstar on Tue Jan 11, 2005 1:06 pm
hey guys anyone know? :D
capcom_allstar
Postby cfitz on Tue Jan 11, 2005 3:03 pm
Sorry, I have no experience with those models. I would have thought the separate converter would have been the right track. This isn't a Macrovision copy protection issue, is it?
Postby capcom_allstar on Tue Jan 11, 2005 6:23 pm
thanks for the reply but no a seperate ntsc to pal coverter does not work
and with macrovsion on this machine you get a "protected content" message
but my machine is saying "wrong signal type"
i really need to solve this
capcom_allstar
Postby cfitz on Tue Jan 11, 2005 7:38 pm
Did you try recording the NTSC signal directly with the system configured as NTSC format? I don't know exactly how to do that, since I don't own and have never used this recorder, but I would suspect there might be something in the set up menu to do this.
If that works, at least you would have transfered from tape to DVD, and then you could rely on the player's automatic signal conversion to convert to PAL on playback.
Postby capcom_allstar on Tue Jan 11, 2005 7:41 pm
yeah tried that already man.. its real puzzling
capcom_allstar
Postby cfitz on Tue Jan 11, 2005 8:36 pm
Well, that exhausts my limited knowledge. Hopefully someone else can give you a hand. Did you try the forums at VideoHelp.com?
Postby capcom_allstar on Wed Jan 12, 2005 4:40 pm
okay man thanks for the help.
i will wait and see if anyone else can solve it here. then try out the other place you said
cheers :D
capcom_allstar
Postby Laher on Wed Jan 12, 2005 5:18 pm
why dont you try going on proper forums like www.videohelp.com
They'll most likely have the answer, or try contacting liteon..webpage
Also upgrade the firmware, disable microvision using hacks available on the webpage
searched this up for you:
http://www.videohelp.com/dvdrecorders.p ... 1#comments
Laher
