LiteOn DVD-ROM LTD 163 DOESN´T WORK
How fast is too fast?
Postby yess on Sat Apr 26, 2003 10:12 am
My LiteOn DVD-ROM LTD 163 can read a CD-ROM but not a DVD-ROM, can someone help me please???
thank you :oops:
yess
Postby CDRecorder on Sat Apr 26, 2003 6:47 pm
Will it read some DVDs and not others, or is there one particular disc it won't play? What type of DVD are you trying to play: data, video, pressed, recordable, etc?
DVD-ROM LTD-163
Postby yess on Sun Apr 27, 2003 3:27 pm
No any DVD, it can not read DVD´S :( , only cd, for music, datas, but not movies... :( :(
Thank you if you can help me, my OS WINDOWS XP PENTIUM 4 256 RAM ..
THANK U
yess
Postby CDRecorder on Sun Apr 27, 2003 3:53 pm
If your drive is under warranty, you should get it replaced. :(
Postby Inertia on Sun Apr 27, 2003 6:09 pm
If your LTD-163 is out of warranty like mine, then you are running out of options. DVD-ROM drives use dual laser pickups because DVD's and CD(R)'s operate at different laser frequencies. It's possible that the DVD optic section has failed, but if not sometimes cleaning a drive will restore it to full function.
At this point you don't have much to lose by trying to clean the drive. There are generic drive cleaning instructions at Clean Your CD-RW
and Simple Recorder Maintenance - Lens Cleaning and Lubrication.
If you decide to try this, let us know if cleaning works. :)
Inertia
Postby vbl117 on Sun Apr 27, 2003 6:55 pm
I assume U know u must use a software ( WinDVD , PowerDVD etc .... ) to read DVD movies . What are the errors messages ?
Also i assume you have enabled DMA on your drive .
vbl117
