LiteON LTR-52327S Media Recognition Problems
Postby EvilMM on Mon Oct 27, 2003 7:21 pm
My LiteON LTR-52327S (52x32x52x) is having problems rcognizing Media, i dont know the exact types, but I have tried Verbatims and PNY Technologies. I just updated to the QS0C firmware from QS09, and no luck, the lite-on site is down, so this is my only hope!
Any and all help is greatly appreciated.
EvilMM
Postby rdgrimes on Mon Oct 27, 2003 7:28 pm
Can you be more specific about what it's doing? Blank media, burned media, software, etc.
rdgrimes
Postby EvilMM on Mon Oct 27, 2003 7:29 pm
It reads all media fine, but when i go to burn, it says to insert media. When i hit disc info, it says no media is in drive.
EvilMM
Postby rdgrimes on Mon Oct 27, 2003 7:38 pm
What software is installed? InCD can sometimes cause similar issues, but usually it gives a message about conflicts and such. I would discount the PNY media, it's pretty cheap stuff, but Verbatim DataLife Plus should work very well.
rdgrimes
Postby EvilMM on Mon Oct 27, 2003 7:40 pm
I use Nero.
Do you have AIM? This might be easier :)
EvilMM
Postby CDRecorder on Mon Oct 27, 2003 7:55 pm
Do you have Alcohol or CloneCD software on your computer? If I understand correctly, they both have an option which intentionally causes this issue to allow copies of certain copy-protected games to work.
Postby EvilMM on Mon Oct 27, 2003 7:58 pm
I do have alcohol 120%, but I've had all that stuff on here for well over 2 months, and it just started this the other day.
EvilMM
Postby rdgrimes on Mon Oct 27, 2003 8:17 pm
In Alcohol, go to options - emulation. Uncheck "ignore media type" and see if that helps.
rdgrimes
Postby EvilMM on Mon Oct 27, 2003 8:18 pm
I dont use it that much, so i uninstalled it.
Still not working.
EvilMM
Postby EvilMM on Mon Oct 27, 2003 11:49 pm
And now it doesnt read anything.
EvilMM
Postby CDRecorder on Tue Oct 28, 2003 2:58 am
The drive isn't reading anything now? If so, try uninstalling the IDE channel to which it is attached in Device Manager and reboot the computer. This will re-install the driver, which may help.
Another thing to try is to boot from a bootable floppy disk in DOS and see if you can read a disc that way. You can find programs to make bootable DOS floppy disks with optical drive drivers at http://www.bootdisk.com.
Postby EvilMM on Tue Oct 28, 2003 6:38 pm
Did a bootdisk, isnt recognizing any CD's, but it does the drive.
EvilMM
Postby CDRecorder on Wed Oct 29, 2003 1:25 am
If you can't even read from the drive in DOS, it's probably dead.
Postby EvilMM on Wed Oct 29, 2003 9:51 am
Thanks for your help, looking into returning for a refund if possible, this is my second lite-on drive.
EvilMM
Postby EvilMM on Wed Oct 29, 2003 2:55 pm
hold on a second, when i run Nero infotool, it says the system ASPI isnt installed.
EDIT: I went to the adaptec site and installed the newest ASPI drivers like it says to do for win XP, now infotool says ASPI installation is corrupted.
EvilMM
Postby CDRecorder on Wed Oct 29, 2003 5:46 pm
Try installing ASPI 4.60. It works better than 4.7x.
Postby dodecahedron on Wed Oct 29, 2003 6:21 pm
Postby EvilMM on Wed Oct 29, 2003 6:28 pm
thx guys, i got the aspi installed and "working properly" according to nero.
Drive still isnt working.
EvilMM
Postby CDRecorder on Wed Oct 29, 2003 7:13 pm
Well, since the drive can't read anything through DOS (even though it is being recognized in DOS), the drive is probably dead. I'd recommend that you try to get another drive.
