Matshita DVD-RAM UJ-811 problem copying files to dcd rom
Postby forsake on Sat Feb 12, 2005 10:43 am
whenever i try to copy my file to the dcd, the window will reponse by saying that there is an error when copying file to the dvd.
my driver is in my laptop nec versa p720
can anyone help me
forsake
Postby bobmitchell on Sat Feb 12, 2005 12:01 pm
Not sure you're going to want to hear this! I have a Toshiba 5205 series portable...and it uses the U-810 drive. The next version of this laptop has the UJ-811 drive. Toshiba has been replacing both drives alot. Seems that they are not the best made / most sturdy drives you can find. I have had mine replace about a month ago and the replacement won't write at all. Luckily it still reads...so I hooked up a USB 2.0 writer to the port and that's how I now burn. If your machine is under warrantee...you might call NEC and get the drive replaced...to read more about the issues thei the Matshita drives go to www.cdfreaks.com Go to the forums and look here: http://club.cdfreaks.com/showthread.php?t=99194
Good luck
Bob
bobmitchell
Postby forsake on Sat Feb 12, 2005 11:24 pm
thanks a lot
the information is very useful
forsake
