Minimum System Requirements
Postby georgeg on Fri Apr 08, 2005 7:03 pm
I was looking at a DVD burner at Costco the other night and I noticed that they listed the minimum system requirements as at least a 700 mhz Pentium III. What do you all think, can you copy and/or burn DVDs with a lessor system? My own pc is marginally better than that (Pentium III 550E o/c to 733 mhz). I can always use the wifes new machine which has a burner but I was just wondering if my old box could handle the load.
georgeg
Postby burninfool on Fri Apr 08, 2005 9:54 pm
The CPU should be ok but there are other things to consider:
1.You should be using Win98SE or newer.
2.You should have at least 128MB of RAM(256MB for video).
3.Your HD should be 7200RPM and have DMA enabled.
4.You might be limited to 4x writing.
Before you buy make sure to install the latest BIOS and chipset drivers for your motherboard(go to your manufacturers website).
Postby spryfly on Sun Apr 10, 2005 6:38 am
If you meet burninfools other prerequisites you should be able to burn at 8x............
"Why? Said the spry little fly."
Nec 3500 LD V2 B6 Quiet
Benq 1620 B7T9 Stock
Liteon 1633sx BS41 Patched for 12x DL Ripping
spryfly
Postby georgeg on Fri Apr 15, 2005 12:22 pm
burninfool wrote:The CPU should be ok but there are other things to consider:
I'm running XP Pro/SP2
384MB
Both my hard drives are 7200 rpm w/DMA enabled.
Its an obsolete board that is no longer supported but I've got the latest BIOS they released.
So, it sounds as if I could do it even if somewhat limited in speed. Thanks. I'll keep the info in mind. Of course, what I really need to do is upgrade the computer. All it will take is a new mobo, new processor, new memory, and probably a new power supply. But hey, I'd get to keep everything else! :-?
georgeg
