Need help between two externals - can't figure it out
Postby lands on Sat Mar 18, 2006 12:04 am
Hi all,
This forum is amazing. I've spent the day doing research, here and elsewhere, but I can't make a final decision...
I need to buy and external DVD burner, and the most important factor is the write quality. I make wedding videos and need the have the best quality writes.
I've narrowed it down to 2 models:
Plextor PX-740UF
and the
Sony DRX-810UL
From what I can tell, the internal versions of these are both based on the BenQ DW1640 which has gotten really good reviews here. However, I can't tell if the external versions are also based on this (similar model # but you never can tell).
So, can anyone give me some recommendations, first hand feedback, or other advice that might help? I really appreciate it.
I was also wondering if you know if I will be able to flash the Plextor external with the BenQ firmware the way you can to the internal?
lands
Postby Ian on Sat Mar 18, 2006 12:35 am
Yes, they're both still based on the BenQ DW1640.
I have not tested the DRX-810UL but I had some problems getting the PX-740UF to read and write at 16x.
Postby lands on Sat Mar 18, 2006 12:45 am
Thanks IAN
Other than the cost factor (which work is paying for) and 16x issue, do you think I should go with the Plextor? I've heard great things about the DW1640. Do you think I can flash the Plextor with the BenQ flash?
lands
Postby VideoRoy on Sat Mar 18, 2006 1:23 pm
lands wrote: Do you think I can flash the Plextor with the BenQ flash?
I doubt you can use the stock BenQ flash to update the drive. You can use BQFlasher if it is a BenQ drive rebadged as Sony or others.
BQFlasher
Kiss your Sony warranty good bye unless you can flash back in case of a return.
DRU500A-2.1A, DRU710A-BYX5, PX716A-1.11, DW1655-BCIB, LH-20A1H-LL0C, GMA-4080N-0S35
Pioneer DVR-633H-s
VideoRoy
Postby Ian on Sat Mar 18, 2006 1:59 pm
Yeah, you'll need BQFlasher if you want to use the stock BenQ firmware.
