Need Help cant figure out what kind of CD's I have
Postby JustRob on Thu Dec 25, 2003 9:01 pm
I have tried to use CDR Identifier 1.63 like I have in the past but it wont work for some reason.
I bought some more Fuji's (Made in Japan). Trying to make sure they are still TY as I have been lucky in the past. The spindle area is opaque but I wanted to confirm that they are TY. Is there any other way to do this other than CDR identifier?
Only difference I see in these VS my other Fuji's is the serial number is circular rather than straight across in the past.
Please help. Thanks in advance.
JustRob
Postby NoSmartz on Thu Dec 25, 2003 9:21 pm
If you have Nero Infotool you can tell that way.
E
Soren Kierkegaard
NoSmartz
Postby JustRob on Thu Dec 25, 2003 9:30 pm
Just went to DL it. I will be honest. Still workin with it but all I am seeing is BLANK CDR. No other info regarding the CD but I will post back. Thanks
JustRob
Postby NoSmartz on Thu Dec 25, 2003 9:50 pm
I believe CDR Identifier isn't working 'cause you don't have an ASPI manager or Layer on your system.Check this link out.Find the CDR Identifier file and read.http://www.lurkhere.com/~nicefiles/
Check out this site to ID your CD's without a program.
http://cdmediaworld.com/hardware/cdrom/cd_cdr_info_abc.shtml
Soren Kierkegaard
NoSmartz
Postby aviationwiz on Thu Dec 25, 2003 11:39 pm
You can use Nero CD Speed. If they have the frosted hub center, and say Made In Japan, then they are TY.
Postby rdgrimes on Fri Dec 26, 2003 12:29 am
Do you have CloneCD or Alcohol installed with the "hide media info" option enabled?
BTW, your best source of media info in Nero 6 is to open a compilation, hit the media info button, then hold down "cntrl-shift" and hit refresh.
Of cource they are TY anyway. you can tell by the dye color if nothing else.
rdgrimes
Postby dodecahedron on Fri Dec 26, 2003 3:51 am
NoSmartz wrote:I believe CDR Identifier isn't working 'cause you don't have an ASPI manager or Layer on your system.Check this link out.Find the CDR Identifier file and read.http://www.lurkhere.com/~nicefiles/
thanks for both links. :D
Postby JustRob on Fri Dec 26, 2003 4:03 am
I think I figured out. Not sure but it is opaque as the others were and they were TY and these were also made in Japan. It was a little easier with that cdr indentifier working but I appreciate the help.
JustRob
Postby NoSmartz on Fri Dec 26, 2003 12:13 pm
Your Welcome
E
Soren Kierkegaard
NoSmartz
