I nEed Urgent Help
I nEed Urgent Help
Postby Arsalan on Wed Feb 01, 2006 3:18 pm
Can some one plz plz help me!?
I need urgent help
I M USING BENQ 4816 firmware updated and is E.09
when ever i try to burn a CDR it gives follwing errorS:
Code: Select all
    SCSI/IDE Error
    ATAPI CD-R/RW 48X16\H0 T1
    Could Not perform fixation
    current program area empty
    invalid write state
My Log file
Arsalan Mahmood
Microsoft
Windows 98 4.10
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 12/10/01 5:32:56 PM
ahead WinASPI: File 'C:\PROGRAM FILES\NERO\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/03 8:18:06 PM
Nero version: 6.3.1.15
Recorder: <ATAPI CD-R/RW 48X16> Version: 9.EK - HA 0 TA 1 - 6.3.1.15
Adapter driver: <ESDI_506> HA 0
Drive buffer : 2048kB
CD-ROM: <ATAPI CD-R/RW 48X16 >Version: 9.EK - HA 0 TA 1 - 6.3.1.15
ATAPI CD-R/RW 48X16 (Target 1, F:): Autoinsert Off, DMA Off, Disconnect Off, SyncDataXfer Off
Excluded drive IDs:
WriteBufferSize: 24117248 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 127MB (130524kB)
Free physical memory: 22MB (23396kB)
Memory in use : 78 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
30.1.2006
CD-ROM (ISO)
12:34:41 PM #1 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
12:34:41 PM #2 Phase 87 File dlgbrnst.cpp, Line 1845
Seamless Link activated
12:34:41 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
12:34:41 PM #4 Text 0 File Writer.cpp, Line 124
Writer ATAPI CD-R/RW 48X16 running
12:34:41 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3899
12:34:41 PM #6 Text 0 File Burncd.cpp, Line 3167
Turn on Track-at-once, using CD-R/RW media
12:34:55 PM #7 Text 0 File DlgWaitCD.cpp, Line 245
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 327574 ( 72:49.49)
12:34:55 PM #8 Text 0 File DlgWaitCD.cpp, Line 257
12:34:55 PM #9 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: ATAPI CD-R/RW 48X16;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:34:55 PM #10 Text 0 File DlgWaitCD.cpp, Line 418
Insert the disc to write to.
(Medium in drive: CD-R. Medium required by compilation: CD-R/RW.)
12:34:56 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
original disc pos #0 + 8461 (8461) = #8461/1:52.61
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 8459 blocks [ATAPI CD-R/RW 48X16 ]
12:34:58 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 983
Prepare recorder [ATAPI CD-R/RW 48X16 ] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 6 to 6:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 17635328, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
318964 | lead-in | 0 | 0x00 | 0x41
318964 | 6 | 0 | 0x00 | 0x41
319114 | 6 | 1 | 0x00 | 0x41
327575 | lead-out | 1 | 0x00 | 0x41
12:34:58 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1029
Removed 2 run-out blocks from end of track 6. Length: 8461 -> 8459.
12:34:58 PM #14 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
12:34:58 PM #15 Text 0 File Burncd.cpp, Line 4177
Cache writing successful.
12:34:58 PM #16 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
12:34:58 PM #17 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 40x (6,000 KB/s)
12:34:58 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2343
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #319114
12:34:58 PM #19 Text 0 File Mmc.cpp, Line 20239
Set BUFE: Seamless Link -> ON
12:36:21 PM #20 SCSI -1093 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02580000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
Sense Code: 0x02
Sense Qual: 0xFF
CDB Data: 0x2A 0x00 0x00 0x04 0xF0 0xCA 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0xFF
12:36:21 PM #21 CDR -1093 File Writer.cpp, Line 304
No seek complete
12:36:21 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
12:36:21 PM #23 CDR -201 File WriterStatus.cpp, Line 196
Invalid write state
12:36:21 PM #24 TRANSFER -18 File WriterStatus.cpp, Line 196
Could not perform EndTrack
12:36:21 PM #25 Text 0 File Mmc.cpp, Line 15064
<ATAPI CD-R/RW 48X16 > start Close Session
12:36:21 PM #26 SCSI -1176 File Cdrdrv.cpp, Line 1188
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x03
12:36:21 PM #27 CDR -1176 File WriterStatus.cpp, Line 245
Session fixation error
12:36:21 PM #28 TRANSFER -19 File WriterStatus.cpp, Line 245
Could not perform Fixation
12:36:21 PM #29 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
12:36:21 PM #30 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
12:36:21 PM #31 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 40x (6,000 KB/s)
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 3/11/02 11:55:38 AM
File 'IoSubsys\CDR4VSD.VXD': Ver=2.2 (031), size=51354 bytes, created 6/21/97 3:00:00 AM
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 4/23/99 10:22:00 PM
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69570 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 4/23/99 10:22:00 PM
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 4/23/99 10:22:00 PM (Adapter driver for rec)
Registry Keys:
Arsalan
Postby Scour on Fri Feb 03, 2006 11:57 am
Did you try different media, different writespeeds?
Toshiba SD-M 1712
Benq DW 1640
LG GH-20N
Postby Arsalan on Sat Feb 04, 2006 7:10 am
Scour wrote:Did you try different media, different writespeeds?
yeah man i have tried different media also CDRW's
on almost all CDR's nero gave me the error which i have written before.
and sometimes i might remind it again "that sometimes" only and only 1 of 20 CDRW is burnt without any error but after the completion of burn process when i open it NO FILES THERE!!!!!
ALAS!!!!!
I NEEEED HELP
Arsalan
Postby Ian on Sat Feb 04, 2006 8:27 am
It looks like you're burning a multisession disc. What happens if you don't?
Green and Nerdy
Postby Arsalan on Sat Feb 04, 2006 9:50 am
Ian wrote:It looks like you're burning a multisession disc. What happens if you don't?
i have tried both multiseesion and NO MULTIsEESION too
also tried different speed like from 20X to 48X
but nothing works :roll:
Arsalan
Postby dodecahedron on Sat Feb 04, 2006 12:55 pm
hello Arsalan, welcome to CDRLabs.
a few things.
1. from the log: "ATAPI CD-R/RW 48X16 (Target 1, F: Autoinsert Off, DMA Off, Disconnect Off, SyncDataXfer Off"
turn DMA on !!!!!
2. from the log: "ISO Level : 1 (Max. of 11 = 8 + 3 char) "
change it to ISO Level 2.
3. from the log: "Burning mode : TAO"
burn in DAO (Disc-at-Once) moce.
4. burn No Multisession, CDR.
from the log: "CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd."
plasmon isn't such great media. see if you can find better media.
Taiyo Yuden, Verbatim.
Location: smack in the middle of Nassaralla's bulls-eye
Postby Arsalan on Sat Feb 04, 2006 1:44 pm
dodecahedron wrote:hello Arsalan, welcome to CDRLabs.
a few things.
turn DMA on !!!!!
The log file that you are seeing is of the time when i changed the system configurations and then tried to burn CD , which also didnt work at all.
well i wanna ask some thing that should i enable DMA for both CD and HardDrive too.
and one thing that i also noticed is that the data is saved as tracks in cdRs although it's saved in a corrupted form ,this happened because CDR was not burnt properly.
and whenever after putting that CDR back into CDRW i can see it's tracks in NERO some times it is readable by nero and smoetimes not.but i cant open these CDR's in explorer.
does this mean that my CDRW is alright?
I have also tried changing media and used MAXELL 52X which also did nto work, and i burnt a BENQ CDRW at 16X which burnt nicely with no probs.
and also tried another CDRW of BENQ ,which said that "BURN PROCESS COMPLTED SUCCESSFULLY" but when i opened it in explorer it was blank.
Arsalan
Postby Arsalan on Sat Feb 04, 2006 2:48 pm
the following errors are of given factors
so can any body now figure out what are these errors all about.
command sequence error|error of CDR
session fixation error|error of CDR
could not perfrom fixation | transfer error
SCSI/IDE Error | error of CDR
ATAPI CD-R/RW 48X16\H0 T1 | error of CDR
Could Not perform fixation | transfer error
current program area empty | error of CDR
invalid write state | error of CDR
Arsalan
All Content is Copyright (c) 2001-2009 CDRLabs Inc.
