nero 6 burner problem
Postby john19 on Wed May 12, 2004 11:10 pm
Hi,
am new to the forum,so hope this is posted in the right area. I have nero 6 and running windows xp but am having problems burning cd's.It reads the data fine no problem but when it comes to writing that information it gets to about 3% of the lead-in and then the red light goes out comes back on and then stops and I get an error message saying burn failed - power callibration error.
It was suggested I disable the Imapi setting which initially helped and i was able to burn 1 cd no problem but now I am getting the same problem again. It seemed to write to a rewriteable cd ok but not a standard CDr.Someone else suggested updating the BIOS but didn't say what to and where to go.I had a look at the properties of BIOS but not sure what if anything in there should be changed?Should the change(if any) be made under the ''compatability'' setting?
Hope someone can help:)
john19
Postby Bhairav on Thu May 13, 2004 1:34 am
Which discs are you using? I'd suggest getting some better media, as a power-calibration error normally indicates crappy discs.
calibration error
Postby john19 on Thu May 13, 2004 5:43 am
hi,I tried that.went from imation to tdk made no difference.Infact have tried so many things,spent hours and hours(no kidding) trying to figure out this damn problem.
Thanks anyway:)
cheers..:)
john19
Postby dodecahedron on Fri May 14, 2004 6:08 am
what kind of motherboard are you using?
what IDE drivers?
Acer 1610a write problems
Postby john19 on Sun May 16, 2004 3:09 am
Hi again
The motherboard is an ABIT BH6 V1.02.
I'm assuming that the IDE drivers are installed under WIN XP
Cheers
john19
Re: Acer 1610a write problems
Postby CCampbell on Mon May 24, 2004 11:28 am
john19 wrote:Hi again
Cheers
If you go to the Ahead website at www.nero.com, you will find an FAQ section that has informatino on possible solutions to the Power Calibration error message.
There are a number of possible causes, and you'll need to go through each possible solution to find the one that will address your issue.
nero problems
Postby john19 on Mon May 24, 2004 3:23 pm
Hi,
all seems ok now.I did go to the Ahead site and contacted them,a few days later they responded with a few possible solutions.
In the end we put in a slightly faster writer and have made sure not to use Imation brand cd's.
john19
nero 6 burning probs
Postby sausage on Mon May 31, 2004 6:09 pm
hello, please help me
i cannot get nero to burn dvds! it keeps telling me that burn process failed after running for about 30 secs i'm using the nero recode feature but it will not complete i'm using nero 6, i,ve tried dvd xcopy but it gives a simalar fault. all versions are up to date i,ve adjusted the virtual memory max to aid running but it still aint avin it HELP!
my system :-
P4 2.4g
512ddr
DVD writers are Pika one+-rw classic and matshita dvd ram (same prob on both)
OS win xp
m/board s478 intel 848p atx a l
media is
bulk pak 4xdvd-r
mirror platinum dvd-r
imition dvd+r (same prob on all 3)
will write cdr with no probs!!
dvd writers are on seperate ide cables and are correctly set SL/MASTER
using dvd decoder prior to burn
HELP HELP HELP
sausage
