Nero burning problem
Postby bja5150 on Mon May 23, 2005 1:08 pm
I got a new Sony 16x DL burner for the computer. It came with a version of Nero and from toying around with it, it seems like a very cool program. So,
I am currently working on a DVD project. I have some 8mm footage I burned to dvd on my Sony RDR Gx7 standalone DVD recorder. The footage is on a DVD+RW disc and came out great. I took it to the computer to do some authoring. I got the files converted to the hard drive as mpegs and loaded them into Nero Express. I have a project worked out that tests fine, but has trouble burning. I have tried a few different things and still no luck. I am getting a little frustrated creating these DVD "coasters" so I thought I would come to you guys for some help. I have included info from the error report and I have updated to the current version Nero. It seemed like everything was going okay and then a engine error came up. It transcoded the menu files fine, went through and was burning the dvd files and died about halfway through the dvd project. Any help would be GREATLY appreciated. If you need the whole error report I still have it, but it was just to big to put it all down.
Brent
I tried again using recode 2 to get the files from the +RW disk and had the same error burn issue. IT is so frustrating when the burner doesn't burn right. It plays perfect on disc and in the preview window, but does not burn right. Something about the structure issue. I'll add all that I can to help.
burn error 05-20-05.jpg (79 KiB) Viewed 1545 times
bja5150
the error report
Postby bja5150 on Mon May 23, 2005 1:12 pm
Here is the error report of the most current burn.
[17:32:24] NeroVision Log created (Date: 05/21/2005)
[17:32:24] NeroVision Processors: 1 (Intel)
[17:32:24] NeroVision OS: Windows Windows XP
[17:32:26] GCCore Detected DirectX Version: 9.0b
[17:32:27] GCHW Node added: Processor
[17:32:27] GCHW Node added: ACPI Fixed Feature Button
[17:32:27] GCHW Node added: Programmable interrupt controller
[17:32:27] GCHW Node added: System timer
[17:32:27] GCHW Node added: Direct memory access controller
[17:32:27] GCHW Node added: HP PS2 Keyboard (2K - 3)
[17:32:27] GCHW Node added: ECP Printer Port
[17:32:27] GCHW Node added: Communications Port
[17:32:27] GCHW Node added: Standard floppy disk controller
[17:32:27] GCHW Node added: System speaker
[17:32:27] GCHW Node added: PCI bus
[17:32:27] GCHW Node added: System CMOS/real time clock
[17:32:27] GCHW Node added: System board
[17:32:27] GCHW Node added: Motherboard resources
[17:32:27] GCHW Node added: Numeric data processor
[17:32:27] GCHW Node added: ACPI Power Button
[17:32:27] GCHW Node added: Logitech PS/2 Port Mouse
[17:32:27] GCHW Node added: Microsoft ACPI-Compliant System
[17:32:27] GCHW Node added: Plug and Play Monitor
[17:32:27] GCHW Node added: Floppy disk drive
[17:32:27] GCHW Node added: CD-ROM Drive
[17:32:27] GCHW Node added: Disk drive
[17:32:27] GCHW Node added: ISAPNP Read Data Port
[17:32:27] GCHW Node added: Printer Port Logical Interface
[17:32:27] GCHW Node added: PCI standard ISA bridge
[17:32:27] GCHW Node added: NVIDIA nForce PCI System Management
[17:32:27] GCHW Node added: Standard Dual Channel PCI IDE Controller
[17:32:27] GCHW Node added: NVIDIA nForce MCP Networking Adapter
[17:32:27] GCHW Node added: Standard OpenHCD USB Host Controller
[17:32:27] GCHW Node added: Standard Enhanced PCI to USB Host Controller
[17:32:27] GCHW Node added: PCI standard PCI-to-PCI bridge
[17:32:27] GCHW Node added: OHCI Compliant IEEE 1394 Host Controller
[17:32:27] GCHW Node added: PCI standard host CPU bridge
[17:32:27] GCHW Node added: NVIDIA nForce2 AGP Host to PCI Bridge
[17:32:27] GCHW Node added: NVIDIA nForce2 Memory Controller
[17:32:27] GCHW Node added: NVIDIA GeForce FX 5200
[17:32:27] GCHW Node added: Creative Audigy Audio Processor (WDM)
[17:32:27] GCHW Node added: Creative Game Port
[17:32:27] GCHW Node added: Lucent Win Modem
[17:32:27] GCHW Node added: Primary IDE Channel
[17:32:27] GCHW Node added: Secondary IDE Channel
[17:32:27] GCHW Node added: ACPI Multiprocessor PC
[17:32:27] GCHW Node added: Volume Manager
[17:32:27] GCHW Node added: AFD Networking Support Environment
[17:32:27] GCHW Node added: Intel AGP Bus Filter
[17:32:27] GCHW Node added: 1394 ARP Client Protocol
[17:32:27] GCHW Node added: Beep
[17:32:27] GCHW Node added: Creative AC3 Software Decoder
[17:32:27] GCHW Node added: Creative DVD-Audio Device Driver
[17:32:27] GCHW Node added: Creative Proxy Driver
[17:32:27] GCHW Node added: Creative SoundFont Management Device Driver
[17:32:27] GCHW Node added: dmboot
[17:32:27] GCHW Node added: dmload
[17:32:27] GCHW Node added: E-mu Plug-in Architecture Driver
[17:32:27] GCHW Node added: fasttx2k
[17:32:27] GCHW Node added: Fips
[17:32:27] GCHW Node added: Generic Packet Classifier
[17:32:27] GCHW Node added: Creative Hardware Abstract Layer Driver
[17:32:27] GCHW Node added: Creative P16V HAL Driver
[17:32:27] GCHW Node added: IPSEC driver
[17:32:27] GCHW Node added: ksecdd
[17:32:27] GCHW Node added: mchInjDrv
[17:32:27] GCHW Node added: MCSTRM
[17:32:27] GCHW Node added: mnmdd
[17:32:27] GCHW Node added: mountmgr
[17:32:27] GCHW Node added: NAVENG
[17:32:27] GCHW Node added: NAVEX15
[17:32:27] GCHW Node added: NDIS System Driver
[17:32:27] GCHW Node added: Remote Access NDIS TAPI Driver
[17:32:27] GCHW Node added: NDIS Usermode I/O Protocol
[17:32:27] GCHW Node added: NDProxy
[17:32:27] GCHW Node added: NetBios over Tcpip
[17:32:27] GCHW Node added: Null
[17:32:27] GCHW Node added: NVIDIA nForce AGP Bus Filter
[17:32:27] GCHW Node added: Creative OS Services Driver
[17:32:27] GCHW Node added: PartMgr
[17:32:27] GCHW Node added: ParVdm
[17:32:27] GCHW Node added: PfModNT
[17:32:27] GCHW Node added: Remote Access Auto Connection Driver
[17:32:27] GCHW Node added: RDPCDD
[17:32:27] GCHW Node added: SAVRT
[17:32:27] GCHW Node added: SAVRTPEL
[17:32:27] GCHW Node added: SbcpHid
[17:32:27] GCHW Node added: SiS AGP Filter
[17:32:27] GCHW Node added: SymEvent
[17:32:27] GCHW Node added: symlcbrd
[17:32:27] GCHW Node added: SYMREDRV
[17:32:27] GCHW Node added: SYMTDI
[17:32:27] GCHW Node added: TCP/IP Protocol Driver
[17:32:27] GCHW Node added: VgaSave
[17:32:27] GCHW Node added: VIA AGP Filter
[17:32:27] GCHW Node added: VolSnap
[17:32:27] GCHW Node added: Remote Access IP ARP Driver
[17:32:27] GCHW Node added: Windows Socket 2.0 Non-IFS Service Provider Support Environment
[17:32:27] GCHW Node added: Audio Codecs
[17:32:27] GCHW Node added: Legacy Audio Drivers
[17:32:27] GCHW Node added: Media Control Devices
[17:32:27] GCHW Node added: Legacy Video Capture Devices
[17:32:27] GCHW Node added: Video Codecs
[17:32:27] GCHW Node added: WAN Miniport (L2TP)
[17:32:27] GCHW Node added: WAN Miniport (IP)
[17:32:27] GCHW Node added: WAN Miniport (PPPOE)
[17:32:27] GCHW Node added: WAN Miniport (PPTP)
[17:32:27] GCHW Node added: Packet Scheduler Miniport
[17:32:27] GCHW Node added: Direct Parallel
[17:32:27] GCHW Node added: Terminal Server Keyboard Driver
[17:32:27] GCHW Node added: Terminal Server Mouse Driver
[17:32:27] GCHW Node added: Plug and Play Software Device Enumerator
[17:32:27] GCHW Node added: Microcode Update Device
[17:32:27] GCHW Node added: Generic volume
[17:32:27] GCHW Node added: Microsoft Kernel Acoustic Echo Canceller
[17:32:27] GCHW Node added: Microsoft Kernel System Audio Device
[17:32:27] GCHW Node added: Microsoft Kernel Wave Audio Mixer
[17:32:27] GCHW Node added: Microsoft WINMM WDM Audio Compatibility Driver
[17:32:27] GCHW Node added: USB Root Hub
[17:32:27] GCHW Node added: Hewlett-Packard ScanJet 5300C/5370C
[17:32:27] GCHW Node added: USB Printing Support
[17:32:27] GCHW Node added: hp deskjet 930c series
[17:32:27] GCHW Node added: 1394 Net Adapter
[17:32:32] ExpressUI Running NeroVision Express 3 Version: 3.0.1.18
[17:32:36] DVDEngine Running DVDEngine version: 3.0.1.24
[17:32:36] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:36] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:36] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:36] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:44] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:44] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:44] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:44] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:44] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[17:32:45] MMTools --- used source filters ---
[17:32:45] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:32:45] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:32:45] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:32:45] MMTools file type MPEG2 - video
[17:32:45] MMTools --------------------
[17:32:51] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[17:32:51] MMTools --- used source filters ---
[17:32:51] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:32:51] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:32:51] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:32:51] MMTools file type MPEG2 - video
[17:32:51] MMTools --------------------
[17:32:51] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:51] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:51] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:51] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:55] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:55] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:32:55] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:55] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:32:55] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_03_1.VOB video/0
[17:32:56] MMTools --- used source filters ---
[17:32:56] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:32:56] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:32:56] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:32:56] MMTools file type MPEG2 - video
[17:32:56] MMTools --------------------
[17:33:01] AMCUIBase VOB import of c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB started, 1 files in group
[17:33:01] AMCUIBase -- AddFile() returned 1
[17:33:01] AMCUIBase -- SetSource() returned 1
[17:33:03] AMCUIBase -- AnalyzeFile() returned 1
[17:33:03] AMCUIBase -- 1 valid segments found
[17:33:04] AMCUIBase -- Using original file
[17:33:04] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB audio/0
[17:33:05] MMTools --- used source filters ---
[17:33:05] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:33:05] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:33:05] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:33:05] MMTools file type unknown - audio
[17:33:05] MMTools --------------------
[17:33:05] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB video/0
[17:33:06] MMTools --- used source filters ---
[17:33:06] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:33:06] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:33:06] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:33:06] MMTools file type MPEG2 - video
[17:33:06] MMTools --------------------
[17:33:08] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB video/0
[17:33:08] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:33:08] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:33:08] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:33:08] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:33:13] AMCUIBase VOB import of c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB started, 1 files in group
[17:33:13] AMCUIBase -- AddFile() returned 1
[17:33:13] AMCUIBase -- SetSource() returned 1
[17:33:18] AMCUIBase -- AnalyzeFile() returned 1
[17:33:18] AMCUIBase -- 1 valid segments found
[17:33:19] AMCUIBase -- Using original file
[17:33:19] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB audio/0
[17:33:19] MMTools --- used source filters ---
[17:33:19] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:33:19] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:33:19] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:33:19] MMTools file type unknown - audio
[17:33:19] MMTools --------------------
[17:33:19] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB video/0
[17:33:20] MMTools --- used source filters ---
[17:33:20] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:33:20] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:33:20] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:33:20] MMTools file type MPEG2 - video
[17:33:20] MMTools --------------------
[17:33:21] GCHW Node removed: Microsoft Kernel Acoustic Echo Canceller
[17:33:26] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:33:26] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:33:26] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:33:26] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:33:26] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB video/0
[17:33:36] AMCUIBase VOB import of c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB started, 1 files in group
[17:33:36] AMCUIBase -- AddFile() returned 1
[17:33:36] AMCUIBase -- SetSource() returned 1
[17:33:40] AMCUIBase -- AnalyzeFile() returned 1
[17:33:40] AMCUIBase -- 1 valid segments found
[17:33:41] AMCUIBase -- Using original file
[17:33:41] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB audio/0
[17:33:42] MMTools --- used source filters ---
[17:33:42] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:33:42] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:33:42] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:33:42] MMTools file type unknown - audio
[17:33:42] MMTools --------------------
[17:33:42] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[17:33:42] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:33:42] MMTools file type MPEG2 - video
[17:33:47] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:33:47] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:33:47] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:33:47] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:33:47] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[17:33:59] AMCUIBase VOB import of c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB started, 1 files in group
[17:33:59] AMCUIBase -- AddFile() returned 1
[17:33:59] AMCUIBase -- SetSource() returned 1
[17:34:02] AMCUIBase -- AnalyzeFile() returned 1
[17:34:02] AMCUIBase -- 1 valid segments found
[17:34:02] AMCUIBase -- User aborted VOB import
[17:34:10] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB audio/0
[17:34:10] MMTools --- used source filters ---
[17:34:10] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:10] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:10] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:34:10] MMTools file type unknown - audio
[17:34:10] MMTools --------------------
[17:34:10] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB video/0
[17:34:11] MMTools --- used source filters ---
[17:34:11] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:11] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:11] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:34:11] MMTools file type MPEG2 - video
[17:34:11] MMTools --------------------
[17:34:14] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:14] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:14] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:14] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:14] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB video/0
[17:34:18] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB audio/0
[17:34:18] MMTools --- used source filters ---
[17:34:18] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:18] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:18] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:34:18] MMTools file type unknown - audio
[17:34:18] MMTools --------------------
[17:34:19] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB video/0
[17:34:19] MMTools --- used source filters ---
[17:34:19] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:19] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:19] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:34:19] MMTools file type MPEG2 - video
[17:34:19] MMTools --------------------
[17:34:21] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:21] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:21] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:21] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:21] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB video/0
[17:34:27] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB audio/0
[17:34:28] MMTools --- used source filters ---
[17:34:28] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:28] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:28] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:34:28] MMTools file type unknown - audio
[17:34:28] MMTools --------------------
[17:34:28] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB video/0
[17:34:29] MMTools --- used source filters ---
[17:34:29] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:29] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:29] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:34:29] MMTools file type MPEG2 - video
[17:34:29] MMTools --------------------
[17:34:39] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:39] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:39] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:39] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:39] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB video/0
[17:34:46] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB audio/0
[17:34:46] MMTools --- used source filters ---
[17:34:46] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:46] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:46] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:34:46] MMTools file type unknown - audio
[17:34:46] MMTools --------------------
[17:34:46] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[17:34:47] MMTools --- used source filters ---
[17:34:47] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:34:47] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:34:47] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:34:47] MMTools file type MPEG2 - video
[17:34:47] MMTools --------------------
[17:34:53] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:53] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:34:53] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:53] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:34:54] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[17:35:00] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_11_1.VOB audio/0
[17:35:01] MMTools --- used source filters ---
[17:35:01] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:35:01] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:35:01] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:35:01] MMTools file type unknown - audio
[17:35:01] MMTools --------------------
[17:35:01] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_11_1.VOB video/0
[17:35:01] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:35:01] MMTools file type MPEG2 - video
[17:35:09] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:09] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:09] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:09] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:09] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_11_1.VOB video/0
[17:35:16] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_12_1.VOB audio/0
[17:35:17] MMTools --- used source filters ---
[17:35:17] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:35:17] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:35:17] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:35:17] MMTools file type unknown - audio
[17:35:17] MMTools --------------------
[17:35:17] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_12_1.VOB video/0
[17:35:17] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:35:17] MMTools file type MPEG2 - video
[17:35:26] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:26] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:26] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:26] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:26] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_12_1.VOB video/0
[17:35:33] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_13_1.VOB audio/0
[17:35:33] MMTools --- used source filters ---
[17:35:33] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:35:33] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:35:33] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:35:33] MMTools file type unknown - audio
[17:35:33] MMTools --------------------
[17:35:34] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_13_1.VOB video/0
[17:35:34] MMTools --- used source filters ---
[17:35:34] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:35:34] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:35:34] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:35:34] MMTools file type MPEG2 - video
[17:35:34] MMTools --------------------
[17:35:40] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:40] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:40] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:40] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:40] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_13_1.VOB video/0
[17:35:48] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_14_1.VOB audio/0
[17:35:49] MMTools --- used source filters ---
[17:35:49] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:35:49] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:35:49] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:35:49] MMTools file type unknown - audio
[17:35:49] MMTools --------------------
[17:35:49] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_14_1.VOB video/0
[17:35:49] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:35:49] MMTools file type MPEG2 - video
[17:35:54] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:54] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:35:54] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:54] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:35:54] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_14_1.VOB video/0
[17:35:59] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_15_1.VOB audio/0
[17:36:00] MMTools --- used source filters ---
[17:36:00] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:00] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:00] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:36:00] MMTools file type unknown - audio
[17:36:00] MMTools --------------------
[17:36:00] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_15_1.VOB video/0
[17:36:01] MMTools --- used source filters ---
[17:36:01] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:01] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:01] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:36:01] MMTools file type MPEG2 - video
[17:36:01] MMTools --------------------
[17:36:04] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:04] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:04] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:04] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:04] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_15_1.VOB video/0
[17:36:12] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_16_1.VOB audio/0
[17:36:12] MMTools --- used source filters ---
[17:36:12] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:12] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:12] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:36:12] MMTools file type unknown - audio
[17:36:12] MMTools --------------------
[17:36:12] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_16_1.VOB video/0
[17:36:13] MMTools --- used source filters ---
[17:36:13] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:13] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:13] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:36:13] MMTools file type MPEG2 - video
[17:36:13] MMTools --------------------
[17:36:18] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:18] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:18] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:18] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:18] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_16_1.VOB video/0
[17:36:23] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_17_1.VOB audio/0
[17:36:24] MMTools --- used source filters ---
[17:36:24] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:24] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:24] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:36:24] MMTools file type unknown - audio
[17:36:24] MMTools --------------------
[17:36:24] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_17_1.VOB video/0
[17:36:25] MMTools --- used source filters ---
[17:36:25] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:25] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:25] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:36:25] MMTools file type MPEG2 - video
[17:36:25] MMTools --------------------
[17:36:28] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:28] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:28] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:28] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:28] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_17_1.VOB video/0
[17:36:32] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_18_1.VOB audio/0
[17:36:33] MMTools --- used source filters ---
[17:36:33] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:36:33] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:36:33] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:36:33] MMTools file type unknown - audio
[17:36:33] MMTools --------------------
[17:36:33] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_18_1.VOB video/0
[17:36:33] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[17:36:33] MMTools file type MPEG2 - video
[17:36:40] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:40] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:36:40] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:40] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:36:40] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_18_1.VOB video/0
[17:37:14] MMTools adding c:\Program Files\Ahead\NeroVision\Video\Black.avi audio/0
[17:37:15] MMTools failed to add c:\Program Files\Ahead\NeroVision\Video\Black.avi audio: 0x8004025d -
[17:37:15] MMTools adding c:\Program Files\Ahead\NeroVision\Video\Black.avi video/0
[17:37:15] MMTools --- used source filters ---
[17:37:15] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:37:15] MMTools {1B544C20-FD0B-11CE-8C63-00AA0044B51E} - AVI Splitter
[17:37:15] MMTools {1643E180-90F5-11CE-97D5-00AA0055595A} - Color Space Converter
[17:37:15] MMTools file type AVI - video
[17:37:15] MMTools --------------------
[17:49:47] GCHW Node removed: Microsoft Kernel Wave Audio Mixer
[17:52:25] GCHW Node added: Microsoft Kernel Wave Audio Mixer
[17:54:12] GCHW Node added: Microsoft Kernel Acoustic Echo Canceller
[17:56:43] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB audio/0
[17:56:44] MMTools --- used source filters ---
[17:56:44] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[17:56:44] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[17:56:44] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[17:56:44] MMTools file type MPEG2 - audio
[17:56:44] MMTools --------------------
[17:56:44] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[17:58:42] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:58:42] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[17:58:43] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[17:58:43] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:02:11] GCHW Node removed: Microsoft Kernel Acoustic Echo Canceller
[18:07:16] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:07:16] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:07:17] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:07:17] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:07:59] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:07:59] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:07:59] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:07:59] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:10:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB audio/0
[18:10:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:10:58] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:10:58] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:10:58] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:10:58] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:13:08] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:13:08] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:13:08] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:13:08] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:13:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB audio/0
[18:13:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:13:49] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:13:55] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB audio/0
[18:13:55] MMTools --- used source filters ---
[18:13:55] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[18:13:55] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[18:13:55] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[18:13:55] MMTools file type MPEG2 - audio
[18:13:55] MMTools --------------------
[18:13:55] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:14:37] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:14:40] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB audio/0
[18:14:40] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:14:56] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:15:04] MMTools adding c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_03_1.VOB audio/0
[18:15:05] MMTools --- used source filters ---
[18:15:05] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
[18:15:05] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[18:15:05] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[18:15:05] MMTools file type MPEG2 - audio
[18:15:05] MMTools --------------------
[18:15:05] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_03_1.VOB video/0
[18:15:49] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_03_1.VOB video/0
[18:15:53] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB audio/0
[18:15:53] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB video/0
[18:16:07] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB video/0
[18:16:12] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB audio/0
[18:16:12] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB video/0
[18:16:34] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB video/0
[18:16:38] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB audio/0
[18:16:38] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[18:16:54] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[18:16:56] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB audio/0
[18:16:57] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[18:17:14] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB audio/0
[18:17:14] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[18:17:39] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[18:17:50] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB audio/0
[18:17:51] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB video/0
[18:17:57] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB video/0
[18:17:58] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB audio/0
[18:17:58] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB video/0
[18:18:07] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB video/0
[18:18:11] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB audio/0
[18:18:11] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB video/0
[18:18:24] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB video/0
[18:18:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB audio/0
[18:18:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[18:18:57] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[18:18:58] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB audio/0
[18:18:58] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[18:19:05] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB audio/0
[18:19:05] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[18:19:19] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_11_1.VOB audio/0
[18:19:19] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_11_1.VOB video/0
[18:19:30] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_11_1.VOB video/0
[18:19:45] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_12_1.VOB audio/0
[18:19:45] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_12_1.VOB video/0
[18:20:05] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_12_1.VOB video/0
[18:20:09] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_13_1.VOB audio/0
[18:20:09] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_13_1.VOB video/0
[18:20:20] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_13_1.VOB video/0
[18:20:23] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_14_1.VOB audio/0
[18:20:23] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_14_1.VOB video/0
[18:20:35] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_14_1.VOB video/0
[18:20:39] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_15_1.VOB audio/0
[18:20:39] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_15_1.VOB video/0
[18:20:43] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_15_1.VOB video/0
[18:20:46] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_16_1.VOB audio/0
[18:20:46] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_16_1.VOB video/0
[18:20:51] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_17_1.VOB audio/0
[18:20:52] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_17_1.VOB video/0
[18:21:03] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_17_1.VOB video/0
[18:21:08] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_18_1.VOB audio/0
[18:21:08] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_18_1.VOB video/0
[18:21:23] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_18_1.VOB video/0
[18:21:26] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:21:26] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:21:27] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:21:27] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:21:31] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:21:31] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:22:23] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB audio/0
[18:22:24] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:22:33] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:22:35] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:22:35] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:22:36] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:22:36] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:22:39] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:22:39] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:23:09] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB audio/0
[18:23:10] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:23:14] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB audio/0
[18:23:14] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:23:22] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:23:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB audio/0
[18:23:27] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:23:57] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:24:04] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:24:04] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:24:04] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:24:04] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:24:07] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:24:08] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:27:37] ExpressUI Burn process started by user.
[18:27:37] ExpressUI Destination: SONY DVD RW DRU-720A
[18:27:37] ExpressUI Directory for temporary files: C:\DOCUME~1\Owner\LOCALS~1\Temp
[18:27:37] ExpressUI ------<NeroVision Project Information>--------
[18:27:37] ExpressUI --- Project type: DVD-Video
[18:27:37] ExpressUI --- Project video options ---
[18:27:37] ExpressUI Video mode: NTSC
[18:27:37] ExpressUI Aspect ratio: Automatic
[18:27:37] ExpressUI Quality: Automatic
[18:27:37] ExpressUI Resolution: Automatic
[18:27:37] ExpressUI Sample format: Automatic
[18:27:37] ExpressUI File type: MPEG-2
[18:27:37] ExpressUI Audio format: Dolby Digital (AC-3) 2.0
[18:27:37] ExpressUI Encoding mode: High Quality (2-Pass VBR)
[18:27:37] ExpressUI --- Project space information ---
[18:27:37] ExpressUI Used disc space: 3.59 GB
[18:27:37] ExpressUI --- Project contents ---
[18:27:37] ExpressUI Number of titles: 18
[18:27:37] ExpressUI 1. Graduation 59 (Video Title, 0h 06m 39s)
[18:27:37] ExpressUI Aspect ratio: 4:3
[18:27:37] ExpressUI Quality: Standard play (5073 kbps)
[18:27:37] ExpressUI Resolution: 720 x 480 (CCIR-601 D1)
[18:27:37] ExpressUI 2. Christmas 62 (Video Title, 0h 03m 45s)
[18:27:37] ExpressUI 3. Pier Point 62 (Video Title, 0h 03m 42s)
[18:27:37] ExpressUI 4. Jim and Jo's 63 (Video Title, 0h 00m 52s)
[18:27:37] ExpressUI 5. Platt BBQ 63 (Video Title, 0h 02m 47s)
[18:27:37] ExpressUI 6. Renee's Baptism 63 (Video Title, 0h 02m 37s)
[18:27:37] ExpressUI 7. Renee's Baptism 63 (Video Title, 0h 01m 35s)
[18:27:37] ExpressUI 8. Nig 63 (Video Title, 0h 00m 39s)
[18:27:37] ExpressUI 9. Renee's 1st bday 64 (Video Title, 0h 04m 10s)
[18:27:37] ExpressUI 10. Father's Day 64 (Video Title, 0h 03m 34s)
[18:27:37] ExpressUI 11. Renee's 2nd bday 65 (Video Title, 0h 03m 43s)
[18:27:37] ExpressUI 12. Orangevale 67 (Video Title, 0h 03m 50s)
[18:27:37] ExpressUI 13. Joshua Tree 67 (Video Title, 0h 02m 45s)
[18:27:37] ExpressUI 14. Mom Shipman 68 (Video Title, 0h 02m 10s)
[18:27:37] ExpressUI 15. Fort Ross 70 (Video Title, 0h 01m 42s)
[18:27:37] ExpressUI 16. Jon's 5th bday 70 (Video Title, 0h 02m 17s)
[18:27:37] ExpressUI 17. Orangevale 71 (Video Title, 0h 01m 50s)
[18:27:37] ExpressUI 18. Water skiing 75 (Video Title, 0h 03m 35s)
[18:27:37] ExpressUI Number of menus: 1
[18:27:37] ExpressUI - Main menu (9 pages)
[18:27:37] ExpressUI --------<End of Project Information>----------
[18:27:38] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:27:38] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:27:38] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[18:27:38] DVDEngine ..Application service registered...
[18:27:38] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[18:27:38] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[18:27:38] DVDEngine ..Session callback registered...
[18:27:38] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[18:27:39] DVDEngine BEGIN: IDVDSessionBaseImpl - BeginDiscAccess
[18:27:39] DVDEngine ..Access mode=read/write
[18:27:39] DVDEngine ..Flags=0
[18:27:39] DVDEngine ..Write speed=5540 KB/s (4x)
[18:27:40] DVDEngine ..Medium type=DVD-R
[18:27:40] DVDEngine DVD format is 1
[18:27:40] DVDEngine Supported Access Modes: 0x00000001
[18:27:40] DVDEngine END: IDVDSessionBaseImpl - BeginDiscAccess
[18:27:40] DVDEngine BEGIN: IDVDVideoSessionImpl - Prepare
[18:27:40] DVDEngine ..BAO activated
[18:27:40] DVDEngine **BEGIN: _DVDVideo - Prepare
[18:27:40] DVDEngine ..VTS_Ns=18...
[18:27:40] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VMG
[18:27:40] DVDEngine ...VMGM_VOBS_exist = true
[18:27:40] DVDEngine ******BEGIN: VMGM_VOBS - Process Create
[18:27:40] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:27:40] NeroVision Analyze video stream
[18:27:40] NeroVision Seg. | frames | weight | volume
[18:27:40] NeroVision ------+---------+--------+--------
[18:27:40] NeroVision 0 | 299 | 2 | 598
[18:27:40] NeroVision total : 598
[18:27:40] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:27:40] DVDEngine ...Duration 100000000
[18:27:40] DVDEngine ..._streamtime_frame_duration is 333667
[18:27:40] DVDEngine ...Stream 0 is 'Video'
[18:27:40] DVDEngine ...Stream 1 is 'System/Stream'
[18:27:40] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:27:40] NeroVision Estimate Size
[18:27:40] NeroVision +-------+------+--------+----------+---------
[18:27:40] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:27:40] NeroVision | 0 | 0 | 1 | 10.00 | 6417
[18:27:40] NeroVision | 1 | 0 | 0 | 10.00 | 0
[18:27:40] NeroVision total data size : 6800003 bytes
[18:27:40] NeroVision multiplexed size : 7045120 bytes
[18:27:40] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_02_1.VOB video/0
[18:27:41] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_01_1.VOB video/0
[18:27:46] DVDEngine ********END: _VOBS - Process VOB
[18:27:46] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:27:47] NeroVision Analyze video stream
[18:27:47] NeroVision Seg. | frames | weight | volume
[18:27:47] NeroVision ------+---------+--------+--------
[18:27:47] NeroVision 0 | 299 | 2 | 598
[18:27:47] NeroVision total : 598
[18:27:47] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:27:47] DVDEngine ...Duration 100000000
[18:27:47] DVDEngine ..._streamtime_frame_duration is 333667
[18:27:47] DVDEngine ...Stream 0 is 'Video'
[18:27:47] DVDEngine ...Stream 1 is 'System/Stream'
[18:27:47] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:27:47] NeroVision Estimate Size
[18:27:47] NeroVision +-------+------+--------+----------+---------
[18:27:47] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:27:47] NeroVision | 0 | 0 | 1 | 10.00 | 6417
[18:27:47] NeroVision | 1 | 0 | 0 | 10.00 | 0
[18:27:47] NeroVision total data size : 6800003 bytes
[18:27:47] NeroVision multiplexed size : 7045120 bytes
[18:27:47] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_04_1.VOB video/0
[18:27:47] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_03_1.VOB video/0
[18:27:53] DVDEngine ********END: _VOBS - Process VOB
[18:27:53] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:27:53] NeroVision Analyze video stream
[18:27:53] NeroVision Seg. | frames | weight | volume
[18:27:53] NeroVision ------+---------+--------+--------
[18:27:53] NeroVision 0 | 299 | 2 | 598
[18:27:53] NeroVision total : 598
[18:27:53] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:27:53] DVDEngine ...Duration 100000000
[18:27:53] DVDEngine ..._streamtime_frame_duration is 333667
[18:27:53] DVDEngine ...Stream 0 is 'Video'
[18:27:53] DVDEngine ...Stream 1 is 'System/Stream'
[18:27:53] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:27:53] NeroVision Estimate Size
[18:27:53] NeroVision +-------+------+--------+----------+---------
[18:27:53] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:27:53] NeroVision | 0 | 0 | 1 | 10.00 | 6417
[18:27:53] NeroVision | 1 | 0 | 0 | 10.00 | 0
[18:27:53] NeroVision total data size : 6800003 bytes
[18:27:53] NeroVision multiplexed size : 7045120 bytes
[18:27:53] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_06_1.VOB video/0
[18:27:53] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_05_1.VOB video/0
[18:27:59] DVDEngine ********END: _VOBS - Process VOB
[18:27:59] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:27:59] NeroVision Analyze video stream
[18:27:59] NeroVision Seg. | frames | weight | volume
[18:27:59] NeroVision ------+---------+--------+--------
[18:27:59] NeroVision 0 | 299 | 2 | 598
[18:27:59] NeroVision total : 598
[18:27:59] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:27:59] DVDEngine ...Duration 100000000
[18:27:59] DVDEngine ..._streamtime_frame_duration is 333667
[18:27:59] DVDEngine ...Stream 0 is 'Video'
[18:27:59] DVDEngine ...Stream 1 is 'System/Stream'
[18:27:59] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:27:59] NeroVision Estimate Size
[18:27:59] NeroVision +-------+------+--------+----------+---------
[18:27:59] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:27:59] NeroVision | 0 | 0 | 1 | 10.00 | 6417
[18:27:59] NeroVision | 1 | 0 | 0 | 10.00 | 0
[18:27:59] NeroVision total data size : 6800003 bytes
[18:27:59] NeroVision multiplexed size : 7045120 bytes
[18:27:59] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_08_1.VOB video/0
[18:27:59] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_07_1.VOB video/0
[18:28:03] DVDEngine ********END: _VOBS - Process VOB
[18:28:03] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:28:03] NeroVision Analyze video stream
[18:28:03] NeroVision Seg. | frames | weight | volume
[18:28:03] NeroVision ------+---------+--------+--------
[18:28:03] NeroVision 0 | 299 | 2 | 598
[18:28:03] NeroVision total : 598
[18:28:03] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:28:03] DVDEngine ...Duration 100000000
[18:28:03] DVDEngine ..._streamtime_frame_duration is 333667
[18:28:03] DVDEngine ...Stream 0 is 'Video'
[18:28:03] DVDEngine ...Stream 1 is 'System/Stream'
[18:28:03] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:28:03] NeroVision Estimate Size
[18:28:03] NeroVision +-------+------+--------+----------+---------
[18:28:03] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:28:03] NeroVision | 0 | 0 | 1 | 10.00 | 6417
[18:28:03] NeroVision | 1 | 0 | 0 | 10.00 | 0
[18:28:03] NeroVision total data size : 6800003 bytes
[18:28:03] NeroVision multiplexed size : 7045120 bytes
[18:28:03] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_10_1.VOB video/0
[18:28:04] MMTools adding cached c:\Documents and Settings\Owner\My Documents\Nero Recode\in order\VTS_09_1.VOB video/0
[18:28:08] DVDEngine ********END: _VOBS - Process VOB
[18:28:08] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:28:08] NeroVision Analyze video stream
[18:28:08] NeroVision Seg. | frames | weight | volume
[18:28:08] NeroVision ------+---------+--------+--------
[18:28:08] NeroVision 0 | 299 | 2 | 598
[18:28:08] NeroVision total : 598
[18:28:08] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:28:08] DVDEngine ...Duration 100000000
[18:28:08] DVDEngine ..._streamtime_frame_duration is 333667
[18:28:08] DVDEngine ...Stream 0 is 'Video'
[18:28:08] DVDEngine ...Stream 1 is 'System/Stream'
[18:28:08] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:28:08] NeroVision Estimate Size
[18:28:08] NeroVision +-------+------+--------+----------+---------
[18:28:08] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:28:08] NeroVision | 0 | 0 | 1 | 10.00 | 6417
[18:28:08] N
bja5150
A quick question too.
Postby bja5150 on Mon May 23, 2005 1:23 pm
PLaying with different programs like DVD Decrptor, DVD author and even Nero Recode to get the video from the disc, one thing was similar and I not sure why. The dvd I made has 22 tracks on the disc. I recorded the footage on the DVD recorder, stopped it, named and recorded another and so on. Once the disc was done I finalized all my work. The disc's main menu page consists of three pages to scroll between. When the computer rips the files to the hard drive there are like double the files. The files are there and they have duplicates. In Nero recode for example it list some as main and extras as shown below. Notice the duplicate like Title 1,24. That is the same footage but repeated. ????? I tried looking that up and haven't found anything on that either. Just curious. This is the last reply. I hope all this helped and if you need anything else or have any other questions feel free to ask.
Brent
Recode 2 window.jpg (80.42 KiB) Viewed 1532 times
bja5150
