Nero data verification doesn't work
Postby Day on Sun Feb 09, 2003 10:50 am
When I turn the data verification function on in Nero, it always says that the disc has errors. But when I do an error scan with CDR Inspector it says that the disc is OK.
Is there something wrong with Nero verification?
Day
Postby Halc on Sun Feb 09, 2003 2:14 pm
Not necessarily.
It could also be that the drive you are using to burn (and to verify) the data in Nero is not very good at reading if off the disk at maximum speed (which I assume Nero is using).
Do you know if CDR Inspector verifies the data at full speed of your drive's reading capability?
regards,
halcyon
Halc
Postby Day on Sun Feb 09, 2003 3:06 pm
Don't know what read speeds both programs use.
The CD is written on LiteOn and is also checked from the same drive
It is read at the default speed that the programs use.
Is CDR Inspector the one I should trust?
Day
Postby dodecahedron on Sun Feb 09, 2003 3:32 pm
what's CDR Inspector?
is it like CDSpeed?
link?
Postby Day on Sun Feb 09, 2003 8:33 pm
dodecahedron wrote:what's CDR Inspector?
is it like CDSpeed?
link?
CDR Inspector by Arrowkey
Day
