Nero7 won't copy audio CD
Postby rudyschatz on Wed Nov 16, 2005 8:21 pm
The following error occurs:
Microsoft Visual C++
Runtime Library
Buffer Overrun Detected
No history file is found in nero7\core
Because program crashes & has to be deleted with the task manager.
Everything worked fine with nero 6.6
rudyschatz
rudyschatz
Postby Bhairav on Wed Nov 16, 2005 11:38 pm
Try uninstalling and reinstalling Nero. On an alternate note : Why don't you try EAC for copying Audio CDs?
Plz help!
Postby waterloo_sunset on Mon Nov 28, 2005 7:14 pm
Even am having this problem. Did a clean re-install which worked. But after a week or so it started giving the same error again. Running 7.0.1.2 on winxp w/ sp2. Can anybody suggest a permanent solution to this? :(
waterloo_sunset
Postby CCampbell on Tue Dec 06, 2005 9:23 pm
I would recommend that you use our new Nero Clean Tool for Nero 7 to uninstall Nero 7 from your system. Then do a fresh install of Nero 7.0.1.2 and see if this resolves your issue. If it does not, then we'll need to see what on your system may be causing a conflict with our Nero 7 software, so that we can try and duplicate and resolve if the problem is with our software.
http://www.nero.com/nero7/enu/Clean_Tools.html
Best Regards,
