Not burning at full speed
Postby playtothebeat on Thu Dec 02, 2004 12:25 am
i have a liteon 851s. it's an internal burner, but i bought an enclosure for it so it is now external (usb 2.0)
i've been able to burn dvds on it just fine, but it doesn't burn at full 8x as it should. a dvd movie takes 18 mins to burn. 8x should take about 8-12 mins as it does on my other 8x (plextor) at home.
im using fuji media (not the best i know.). it's 8x media.
i downloaded kprobe2, but it for some reason does not recognize the media. is there a firmwire update or something i can download?
any help would be aprpeciated. i'd like to burn at 8x like the burner is capable of..
playtothebeat
Postby playtothebeat on Thu Dec 02, 2004 1:03 am
i tried installing the firmware (GS0K) from LiteOnit.com and i get a message that says
"No matched drive selected! This utility is only for LITE-ON DVDRW LDW-851S drive.
1-0-0-0 D: HL-DT-STRW/DVD GCC-4241N 0C29
2-0-0-0 E: Generic DVD-Rom 1.0
2-0-0-0 F: LITE-ON DVDRW LDW-851S GSC2
The DVD/CD Drive you use need not apply to this updating program."
so that's really weird. it sees the drive but doesn't seem to use it for the firmware.
not sure if it's my jumper setting or what...
on the liteon drive, the jumper is set to ": | :" (on the midde one). should i change that?
playtothebeat
Postby hoxlund on Thu Dec 02, 2004 1:06 am
if you have burner in external case, it should always be master
Postby playtothebeat on Thu Dec 02, 2004 1:16 am
alright i did that, but the program i d/led from liteonit.com still can't install..
playtothebeat
Postby hoxlund on Thu Dec 02, 2004 1:20 am
what about just popping it back into your computer just to update the firmware?
you don't even have to mount it, just let it hang there in your open case with ide and power cable connected
Postby playtothebeat on Thu Dec 02, 2004 1:46 am
my computer is about 1000 miles away :)
if i can get to it over the christmas break, ill do that..
by the way, after changing to Master Kprobe can now display Disc Info.
playtothebeat
