P4C Temp/Fan Question..
Postby BurninMan921 on Wed Dec 03, 2003 9:55 pm
Hi all, just got a Pentium 4C 2.4GHz. This thing runs ~55C under load, which seems kinda high. Is it? What's a good "safe" temp? I do want to OC a soon as I get my new memory.
I am using the stock heatsink/fan...which had a thermal pad on it instead of paste. Before overclocking, I was going to remove the thermal pad and put some Artic Silver 2 on it. Or should I just get a whole new heatsink/fan? What would a good (quiet!) one be? The local store carries Cooler Masters, I think...
Also, does anyone know if the MSI 865PE Neo2 boards "lock" the memory speed if the FSB is OC'd? Right now I don't want to OC because I have old, PC2100 (266MHz) memory in the system, which didn't seem very tolerant of OC'ing in my old system. I plan on replacing it with Kingston HyperX 500MHz DDR, which, if the FSB is OC'd, would give me 1GHz Memory and a 3GHz CPU, with the memory still running "in spec".
Thoughs? Other than that I tend to ramble in my posts? :wink:
BurninMan921
Postby integspec on Wed Dec 03, 2003 10:03 pm
Burnin,
Can you tell what's the usual ambient temp where your pc is? I think maybe 55C is little too high. Others might opine differently but around 45C is normal right?
Also while it's at 55C OC is not a good move. Maybe already you are aware, Temp is the OC killer.
Nor iron bars a cage;
Minds innocent and quiet take
That for an hermitage;
If I have freedom in my love,
And in my soul am free,
Angels alone that soar above
integspec
Postby aviationwiz on Wed Dec 03, 2003 10:04 pm
That does seem kind of high. Dumb question, but is it hot in the room, with or without the computer on?
Also, I would recomend a Thermaltake HSF used on slow fan level.
Postby integspec on Wed Dec 03, 2003 10:20 pm
Here is a site from where you can get loads of info on Heat Sinks/coolers:
http://www.dansdata.com
Dan really runs a good site.
integspec
Postby BurninMan921 on Thu Dec 04, 2003 8:15 am
System temp at idle is 38C, with idle CPU temp at ~44C or less.
It's not that hot in the actual room.
Maybe it's because the fan has the stupid thermal pad on it? I'll be ordering a new fan ASAP...
BurninMan921
Postby BurninMan921 on Fri Dec 05, 2003 7:24 pm
Well, guess I won't even be doing a 1MHz overclock :evil:
The stupid mobo can't lock the PCI/AGP bus speeds! And this from a board that MSI tries to pimp to overclockers; it even has a big "D.O.T." sticker on it. Argh! Even my old, 1st gen Abit 845 mobo could lock the PCI/AGP bus.
Well, guess I'll be getting that nice Gigabyte 875 P4 Titan board...
BurninMan921
Users browsing this forum: No registered users and 10 guests
