pioneer dvr 108 firmware 1.6?
Postby machoboy6 on Mon Aug 16, 2004 10:19 pm
so where can i get this firmware? is it official? i just got this drive and so far it hasnt recognize my ridata 4x dvd+r from newegg or newegg's own 4x dvds.
machoboy6
Postby dhc014 on Tue Aug 17, 2004 12:04 am
Yes it's official. You can get it from Pioneer Japan or Pioneer Australia's Firmware pages.
dhc014
Postby machoboy6 on Tue Aug 17, 2004 1:18 am
ok this drive sucks. no wonder i got it for 100 bucks. i just updated the firmware to 1.6 thinking it would solve my media recognition problem but it didnt. i have tried verbatim 4x dvd+r that was made in taiwan, ridata 4x dvd+r that was also mad in taiwan and riteks g4 4x dvd-r. the drives doesnt recognize any burnt dvds i made before either. it does read cds though. im going to return this and get a refund.
machoboy6
Postby dhc014 on Tue Aug 17, 2004 1:33 am
:^o
dhc014
Postby hoxlund on Tue Aug 17, 2004 2:41 am
you should read reviews before making a purchase like that
if 4x media is what your looking to burn, go with pioneer 107
also burns a lot of 4x dvd-r media at 8x with great results, namely the ritek g04 you said you bought
PIONEER A108
Postby sqlb on Tue Aug 17, 2004 11:09 am
Is it really the drive. I have the same Pioneer A-108 (NewEgg) and using the Ridata 4X & 8X DVD+R media, I have successully burned 12 discs with zero failure. What burning software is being used? I'm using the latest Nero 6 released last week.
sqlb
Postby hydrogen on Tue Aug 17, 2004 1:42 pm
You might have a bad drive. You should probably send it back and get another one.
hydrogen
Postby dolphinius_rex on Tue Aug 17, 2004 1:44 pm
luckily Pioneer doesn't have a reputation for having 3 or more bad drives in a row (unlike the Plextor 712a :wink: )
Postby machoboy6 on Tue Aug 17, 2004 4:04 pm
i cant use any program because the drive says there's no disc inside. i go to my computer and check the contents of the disc and its as if there's nothing inside.
machoboy6
Postby hydrogen on Tue Aug 17, 2004 4:11 pm
machoboy6,
Just exchange it for another one. It might be a bad drive.
Also, have you checked the bottom of the disc to see if any data was actually burned to the disk?
Does it recognize a dvd movie? If it does, then there maybe a problem with the burner not burning.
What store did you buy it from?
When you say it won't read a burnt dvd that was previously burnt, do you mean by another drive or something?
What happens if you burn a disc with the Pioneer? Does it read back in the Pioneer and any other dvd drives you have?
Do you have another dvd burner in your computer and does it work? If so, I would sent the Pioneer back and get a new one. I'm sure it is just a bad drive. It happens :(
hydrogen
Postby machoboy6 on Tue Aug 17, 2004 11:46 pm
i got it from newegg.com and returning it for a refund. told them it was defective. the drive just doesnt read any kind of dvds. i tried movies and data dvds that have been burnt and working on my pioneer 105 with no luck. even with blank dvds the drive fail to recognize it. so i cant tell you if any data is burnt on the dvd because the drive thinks there no dvd media at all inside even though there is. it just spins for like a minute with the green light on everytime i put any kind of dvds in. so im almost positive it was a bad drive. im just going to wait if other people have the same problems or a drive with similar or better specs comes out.
machoboy6
Postby hoxlund on Wed Aug 18, 2004 1:54 am
yeah sounds like bad drive
but also i would highly recommend getting another pioneer 107
you guys probably have no clue how many dvds i burn in my 107, my movie collection is up to 431, i repeat 431 dvd movies
Postby hydrogen on Wed Aug 18, 2004 2:31 am
Like hoxlund said it sounds like a bad drive.
I would buy another one and see if it works.
hydrogen
