Please recommend a combo drive (DVD-ROM/CD burner combo)
Postby klrmowse on Wed Mar 30, 2005 11:09 pm
a beige one would do; good quality and compatibility.
Mt. Rainier support a plus.
Thx's in advance
klrmowse
Postby dodecahedron on Wed Mar 30, 2005 11:15 pm
Lite-On combo drives.
http://www.liteonit.com/ODD/English/e_p ... _combo.asp
SOHC-5232K, SOHC-5235K, SOHC-5236K
all of them are more or less the same drive (35, 36 are slightly newer versions).
Postby burninfool on Thu Mar 31, 2005 12:49 am
I have the 5232 and it rips a DVD-5 at 14x,it can be made regionfree with LtnRPC or KProbe.The quality isn't the best but for $44US I can't complain.
Postby hoxlund on Thu Mar 31, 2005 12:13 pm
be careful with litey combo drives, if you plan on using it for ripping think again
ive gone through... lets see... 3 combo liteys so far, all of em didn't last more then 2 months
so this time i just went with the nec 3520 for my combo drive
only $14 more then the litey combo drives now
http://www.newegg.com/app/ViewProductDe ... 035&depa=1
$52.99 w/shipping
Postby eric93se on Thu Mar 31, 2005 2:19 pm
I have an LG combo drive and never had any trouble from it. Its an older model and LG didn't give much firmware support, but the latest combo drive has had many updates. And it has Mount R. support, I never used it though.
Benq DW-1640
eric93se
Postby GTMan on Thu Mar 31, 2005 8:16 pm
I bought the Sony CRX320A combo drive, it works well and has a good brand name. It is an off-white color and fairly quiet. A bit slow in recognizing discs some times but maybe all drives have that problem.
52x CD-R (read and write)
32x CD-RW (ultra-speed plus writing logo)
16x DVD-ROM
Supports Mt. Rainier
You can buy 24x CD-RW discs now so burning and formatting CD-RW is much faster with this drive.
GTMan
Postby Bhairav on Thu Mar 31, 2005 11:23 pm
GTMan wrote:I bought the Sony CRX320A combo drive, it works well and has a good brand name. It is an off-white color and fairly quiet. A bit slow in recognizing discs some times but maybe all drives have that problem.
16x DVD-ROM
It's a Lite-On 5232K rebadge.
