Plextor Premium stuck in PIO mode
Postby aviationwiz on Wed Mar 03, 2004 9:54 pm
As the title says, my Premium is stuck in PIO mode. I can't get it into DMA. I've tried the FAQ's, selecting "DMA if availible" and uninstalling the channel and having it load up after a restart. Nothing. My PX-708A and PX-116A are still in DMA though.
The Premium is Primary Master (or Primary Primary if you live in CA :lol: :lol: , note: see old old thread)
The PX-116A is Primary Slave (or Primary Secondary :lol: )
the PX-708A is Secondary Master (or Seconday Primary, :lol: )
Motherboard is a P4C800-E Dlx. and I just can't get it figured out as to why I can't get this burner into DMA. The jumper is set to "Master" which is where it should be. Any ideas? I'd give Plextor Tech Support a call, but they'll probably tell me I should use different media, :lol: :lol: .
Postby dolphinius_rex on Wed Mar 03, 2004 10:02 pm
There is a jumper setting on the back of the Premium for various form of DMA, try setting it or not setting it...
also, check your bios options, perhaps there is a setting there that got messed up?
Postby aviationwiz on Wed Mar 03, 2004 10:18 pm
In addition to the Master, or take the jumper off of Master and put it on the DMA switch?
Postby dodecahedron on Wed Mar 03, 2004 10:19 pm
Postby aviationwiz on Wed Mar 03, 2004 10:28 pm
Thanks, cfitz's plan worked.
Postby dodecahedron on Wed Mar 03, 2004 10:32 pm
welcome :)
