Plextor W4012TA problems...
Postby L10nH34Rt on Tue Aug 05, 2003 11:23 am
Here is what I experience
1) The drive can read perfectly all types of cds
2) Using Nero CD/DVD speed I managed to complete perfectly the write test
3) I can erase any CD-RW media
4) When it comes to actually writing something on the cd Nero always fails on lead-in. In fact it writes nothing at all on the cd and the cd can be used again on my ASUS 52x\24x\52x CD-RW drive.
Any ideas?
Life will not always be this way...
Look around, hear the sound, cherish your life while you're still around...
L10nH34Rt
Postby dodecahedron on Tue Aug 05, 2003 1:36 pm
strange.
1. try to upgrade to the latest 1.05 firmware.
http://www.plextor.be/english/technical ... 012TA.html
2. make sure DMA is enabled.
check out the FAQ:
3. check your IDE drivers. what chipset/motherboard do you run the drive off? try to update to the latest drivers, or switch from the motherboard makers's drivers to the default MS drivers.
Postby Inertia on Tue Aug 05, 2003 5:44 pm
L10nH34Rt,
Have you tried a different brand of high quality media? If you are experiencing this failure with only one type of media, it may be incompatible with the Plextor. If a burner can't successfully calibrate its laser to media requirements, the burn can fail at lead-in due to calibration error.
Even though the current media works with the other burner, it could still be the problem. It's worth a try to experiment with other media before determining that the Plextor is at fault.
Inertia
