Nutech 081/082 DVD±R/RW and PC game Copying?
Postby NoSmartz on Tue Mar 16, 2004 3:12 pm
I was reading the review of the afformentioned drive and was looking at the section on what games it could copy with certain copy protection embedded.Read here.This drive did most copies but not all cause of certain copy protections.I was under the impression that you can .bin/cue or .iso a game disc and that was an "exact copy" and you could play it with no problem.Can someone shed some light on this subject.
E
Soren Kierkegaard
NoSmartz
Postby cfitz on Tue Mar 16, 2004 7:07 pm
Copy protection generally relies on certain characterstics of the physcial CD structure that are not and can not be captured in .bin/cue or .iso formats. The .bin/cue and .iso formats are only exact copies of a standard CDs written in a standard format, and they only include information at a higher level of abstraction than the physical layer. For an analogy, consider copying a simple text file from a CD to a floppy. That creates an exact copy of the file, but you can't put the floppy in your CD drive and read it because the physical characteristics weren't copied exactly.
Similarly, CD copy protections tweak the physical characteristics of a CD to push the CD outside of normal CD specifications so that it is difficult to copy but is still readable. You can read a little about one such characteristic here.
What I have written here is a very brief overview of a very complex topic, so naturally it glosses over a lot of detail and omits a lot of information. Search around on the web to learn more. As you probably know by now given the source you linked, our friends at club.cdfreaks.com are a good resource for information about copy protection.
Postby NoSmartz on Tue Mar 16, 2004 8:01 pm
Yeah I borrowed a backup of Gta 3 a few years ago and it never would work right.Guess that CP was to good for whatever tried to copy it.Then again I've used a few back't up games and they have work't and I'm pretty sure they were done with clonecd or something like that.Guess it depends on a lot of factors.That cdrlab link has a ton of info.Gonna take some time to look over.
E
Soren Kierkegaard
NoSmartz
