Is my BenQ drive defective?
Postby vio_man on Sun Feb 06, 2005 2:25 pm
I bought a 1620 drive manufactured at Malasya (December 2004). I've been using it for 2 weeks with no problems at all. Now suddenly it refuses to burn or stops burning my Prodisc S03 media with the following error (the LBA address is not always the same):
18:16:24 (G BENQ DVD DD DW1620(1:1) - [Write ERROR] LBA: 391984, Length: 16
S:KEY - 03/0C/00 - "Write Error"
I thought it could be a defective disc, and tried another disc from the same cakebox and it takes much more time to detect discs and sometimes doesn't even start to burn or stops while burning. Should I RMA my drive?
vio_man
Postby vio_man on Sun Feb 06, 2005 2:34 pm
I already tried a new cakebox and the problem remains. Sometimes it doesn't even recognizes the blank media.
vio_man
Postby Graham35 on Sun Feb 06, 2005 2:44 pm
Must be them prodisc you been using (lol)
Graham35
Postby vio_man on Sun Feb 06, 2005 2:47 pm
Don't think so, I've burned at lest 15 Prodisc with this burner with no problems at with low error levels. The problem appeared suddenly.
vio_man
Postby RJW on Sun Feb 06, 2005 4:29 pm
Prodisc spindles sometimes have terrible variations in quality.
Hmm I would suggest first try something else.
(TY,MCC(only branded as verbatim or SOny since the small cheap-ass brand stuff quality is really fluctuating that much !),Maxell)
Postby dolphinius_rex on Sun Feb 06, 2005 8:09 pm
Most Prodisc media fail in my BenQ DW1620. Only PRODISCR03 media burns properly at all. From some other drives I've worked with, I mostly put the blame on Prodisc for this one. Yes even PRODISCS03 media doesn't work right. Don't even try Prodisc 8x DVD-Rs.
Pretty much anything will work better. Optodisc, Ritek, maybe even Princo! For best results, use Acro Circle 8x DVD-Rs at 4x, or use Taiyo Yuden 8x DVD+Rs (at 8x) :wink:
Postby DVD_ADDICT on Sun Feb 06, 2005 8:32 pm
FujiFilm media doesn't work well with the 1620 drive. It's sold under MEMOREX DVD-R. That's the only media that makes coasters. I don't know why but they burn flawlessly in my pioneer 107 and plextor 708a drive.
DVD_ADDICT
Postby dolphinius_rex on Mon Feb 07, 2005 2:17 am
DVD_ADDICT wrote:FujiFilm media doesn't work well with the 1620 drive. It's sold under MEMOREX DVD-R. That's the only media that makes coasters. I don't know why but they burn flawlessly in my pioneer 107 and plextor 708a drive.
A lot of Fujifilm media is made by Prodisc... and as I said, Prodisc and BenQ do not get along... although FUJIFILM03 code discs made by MBIL don't work in the BenQ DW1620 either.
Postby vio_man on Mon Feb 07, 2005 8:55 am
I've burned as much as 15 Prodisc S03 discs with the 1620 drive with no problems, I even posted a scan here. Also a friend of mine with a 1620 drive can write Prodisc S03 discs with low level errors.
vio_man
Postby dolphinius_rex on Mon Feb 07, 2005 11:14 am
vio_man wrote:I've burned as much as 15 Prodisc S03 discs with the 1620 drive with no problems, I even posted a scan here. Also a friend of mine with a 1620 drive can write Prodisc S03 discs with low level errors.
I posted a scan too :wink:
http://www.cdrlabs.com/phpBB/viewtopic. ... 715#134715
I've had better results with almost every other manufacturer of media then I have with any Prodisc DVD-Rs. Some exception include Princo and Infomedia (Hyundai brand).
Postby vio_man on Mon Feb 07, 2005 1:34 pm
Here are the news. I went to Staples and they swapped the drive immediately. Just flashed B7T9 and burned a ProdiscS03 disc. It burned until the end, with no errors :D QScan also works great :D
The other drive was defective as I thought. But this new 1620 doesn't burn ProdiscS03 media like the previous. It produces much higher error levels, but the discs are readable.
It seems that the Prodisc burn quality is related with the drive's optics, maybe the PHU.
vio_man
Postby dolphinius_rex on Mon Feb 07, 2005 4:12 pm
I still don't think the other drive was defective neccessarily, but it DOES sound like it was a quality variation issue.
remember, BenQ can only scan for certain types of errors, and I've had (and even posted) scans of media that looked great, but were completely unplayable in my PX-712a (which isn't a BAD reader).
Of course, the way drives are being made these days, if you keep returning and replacing them, eventually I'm sure you'll find one that works :P That was true with the PX-712a and PX-716a, and also the NEC 2500a :o
Postby vio_man on Tue Feb 08, 2005 12:56 pm
Look at this excellent scan with ProdiscS03 media
vio_man
Postby dolphinius_rex on Tue Feb 08, 2005 3:08 pm
vio_man wrote:Look at this excellent scan with ProdiscS03 media
If you scanned it at 8x, it would probably look even closer to MY scan:
Which I already posted in the BenQ DW1620 review thread discussion...
This disc however, despite looking pretty is also completely useless in my PX-712a.
I don't quite understand why it is so hard to prove to you that Prodisc has quality variation problems :-?
Postby vio_man on Tue Feb 08, 2005 4:03 pm
Because I have burned more than 50 ProdiscS03 discs with my old NEC 2500 and my new BenQ, and the only problem occurred with a faulty BenQ drive. That's why it's not easy to convince me.
vio_man
Postby dolphinius_rex on Tue Feb 08, 2005 4:14 pm
vio_man wrote:Because I have burned more than 50 ProdiscS03 discs with my old NEC 2500 and my new BenQ, and the only problem occurred with a faulty BenQ drive. That's why it's not easy to convince me.
So all the problems other people have, not to mention the OEM brands that Prodisc stuffs with crap mean nothing?
To say ABSOLUTELY nothing of Prodisc's current media :roll:
Postby vio_man on Tue Feb 08, 2005 4:24 pm
All my Prodisc's are eProformance, maybe other brands may have lower quality Prodisc discs. I also used Prodisc R03 and they worked just fine with my previous NEC 2500.
vio_man
Postby dolphinius_rex on Tue Feb 08, 2005 5:00 pm
Hrm... just noticed you live in Portugal. Maybe you get the good batches?
We'll see how much you like Prodisc at the end of February when they run out of 4x :wink:
Postby vio_man on Tue Feb 08, 2005 6:10 pm
My 4x stock is getting really low (about 12 pcs). I've just ordered Platinum DVD+R 8x (RICOHJPN02) media
vio_man
Postby dolphinius_rex on Tue Feb 08, 2005 7:29 pm
vio_man wrote:My 4x stock is getting really low (about 12 pcs). I've just ordered Platinum DVD+R 8x (RICOHJPN02) media
THe RICOHJPN02 media I've used has been good... but much better at 8x then the usually supported 12x.
Postby vio_man on Wed Feb 09, 2005 9:22 am
The one I'm buying is supported at 16x with the official B7T9 firmware.
vio_man
Postby dolphinius_rex on Wed Feb 09, 2005 11:38 am
I said *usually* supported 12x :wink: Yes, the BenQ supports it at 16x.
