Dartman wrote:Try updating to the newest version 7.054 I think. The Label flash Icon is different then the Light Scribe one also. Maybe I just got lucky, but it worked after I put the dll in that directory. Otherwise you'll have to get a label flash serial or something.
My 6 never worked either, but 7 does ?!
Liggy wrote:Binflash 1.24 or earlier should not be made available in any way! :cop:
Dartman wrote:I think Liggy finally admited he was getting pressured from someone (not NEC) to drop anything that enabled crossflashing so he relesed a locked version so crossed cards wouldn't flashHe doesn't want to get sued and I guess he didn't want to release it after whatever happened but it got out anyways so now it's damage control.
Mine worked fine with 1.24 and I think so has most people that have tried it.
TCAS wrote:Another burn with NEC 3550@4551 using Staples "Playo" DVD+R on sale this week for $4.99 per count of 50. The MID of the disc is AML 002: Not bad for the DVD disc at 10 cents each.
Ian wrote:Yet his NEC Drive Convertor utility is still available...
nomadh wrote:To: the gdog....... BTW I also bought those staples AML +r 8x disks and I burned them at 16x on my benq and got a quality score in the high 90's. They are made in china so I was very suprised at how well they came out. And at double the rated speed even! I saw that even someone with a btc had a great burn so they may be great. They were certainly better than those horrible sony mij 8x +r.
nomadh wrote:Too bad. Maybe its online. Or another store. My store is in a more residential area and I happened to be out at 10am sun morn and there was just a few of us there. Went back mon eve with a friend and still plenty.
nomadh wrote: I wonder if the downside is they turn to dust in 1 yr. Its a communist plot I tell ya!![]()
| All Content is Copyright (c) 2001-2026 CDRLabs Inc. |
