What brand cd-rw drives are these TDK cd-rw drives? Plextor?
Postby BuddhaTB on Fri Dec 06, 2002 7:12 pm
TDK's 52x24x48 drive is made by Lite-On. They just stated a lower speed for the CD-Rom read speed, but I'm pretty sure it will read ta 52x like all other Lite-On 52x24x52 drives.
TDK's 48x24x48 is made by Lite-On too. The box says 16x re-write, but it can be upgraded to 24x re-write with firmware. This is the drive I use. :D
BuddhaTB
Postby liteoncrasher on Sat Dec 07, 2002 8:30 am
I've noticed quite a few people have multiple CD-RW drives listed in their system list signatures. Why is this? Can these people make more than one copy of CDs at the same time. What else could be the advantage to this set up?
Sorry for being off-topic :-?
liteoncrasher
Postby imtim83 on Sat Dec 07, 2002 8:35 am
liteoncrasher well i am guessing if both cd-rw drives have burn proof and you have two ide HDs or a SCSI HD you can burn two cds at once pretty easily. Not sure how it would do on one ide HD trying to burn two cds from data off the one IDE HD. Heck you could have 4 cd-rw drives which would rock with all burn proof and burn four cds at once! Oh yeah!!!!
I guess it would just be best to have either 4 ide HDs to do that all at the same time or one SCSI HD. Heck you could even do 10 cds at once i bet if you had 10 cd-rw drives just have to have a enough drive bays or get external cd-rw drives.
Any help appreicated
Please Reply
imtim83
Postby cfitz on Sat Dec 07, 2002 9:19 am
I suspect a lot of it is simply due to upgrading to the latest and greatest. Someone has a CD-RW that they are happily using, and then finds a newer, better one at an irresistible price (there have been a lot of those lately) and succumbs to temptation. Then, since the older drive still works fine or has some particular feature the new drive doesn't, the happy new CD-RW owner keeps both.
That is how I ended up with a Yamaha CRW3200EZ (excellent quality, special AMQ music recording feature) and a Memorex/LiteOn 48x24x48 (high speed, only $40).
Postby imtim83 on Sat Dec 07, 2002 9:56 am
cfitz have you ever tried burning 2 cds at once? I can't because my old HP 9110i 8x 4x 32x cd-rw doesn't have burn proof :( Thats one of the biggest reasons why i wanted to get a new cd-rw drive because i wanted burn proof so bad so i could use my computer while burning a cd!! So thats why i brought my plextor 24x 10x 40x cd-rw and i really have no reason to upgrade from that now inless it dies or whatever. I am just happy i have burn proof i just wish my other cd-rw did too.
Please Reply
imtim83
Postby cfitz on Sat Dec 07, 2002 10:10 am
Sorry, no I have not.
Postby imtim83 on Sat Dec 07, 2002 10:12 am
cfitz ok. I wish i could try that. If i could i would because i know it would work i bet. Even with one ide HD but i think it would sorta take double the amount of time sense the ide HD could only do one at a time i think. Inless you have 2 ide HDs on two different ide channels. Or a SCSI HD.
Please Reply
imtim83
Postby cfitz on Sat Dec 07, 2002 10:16 am
You should be able to do it, even without buffer underrun protection on the one drive, as long as you burn slowly enough. And no, it won't take twice as long. In fact, it should take about the same amount of time as burning a single disc at the selected speed. The reason for this is that CD-RW transfer rates (assuming DMA is enabled) don't stress an IDE channel, so two drives could easily share the bandwidth without appreciably slowing down each other.
By the way, I am talking about burning the same image to two different CD-R discs simultaneously, not burning two separate images, one to each of two different CD-R discs.
Multiple drives...
Postby scottm on Sat Dec 07, 2002 5:07 pm
There's two programs that let you burn multiple drives at once....one is Nero (2 w/ retail version--plus it's red-headed stepchild Feurio can on the pay version)...and the better way to do it is Cd Mate. Check Ian's review of both of these...CD Mate is recommended if you want up to 6 (!) drives going at once (like my DJ friend).
scottm
Re: Multiple drives...
Postby Tall Texan on Mon Jan 27, 2003 4:12 pm
scottm wrote:There's two programs that let you burn multiple drives at once....one is Nero (2 w/ retail version--plus it's red-headed stepchild Feurio can on the pay version)...and the better way to do it is Cd Mate. Check Ian's review of both of these...CD Mate is recommended if you want up to 6 (!) drives going at once (like my DJ friend).
Ok i just had to try this so i downloaded the trial of cd mate and gave it a shot and i burned to copies of a full iso in 4.25 mins. I used two samsung CD-Rs one is a sw-240 the other is a sw-248 either will burn a fill disk in 2 mins by its self so it does look like doing two at once does slow it down some. Im thinking that is do to the fact that thay where on the same ide chn. im gona try in a little bit to see if it makes a diff to put them on a diff chn. then im also gona try doing to diff cds at once and see what i can come up with.
AMD XP - 1900
1 gig DDR
80 gig WD 7200 x 2
ATI Radon 7200 64meg.
Samsung 16x DVD black
Samsung 40x12x40 CD-RW black
Samsung 48x16x48 CD-RW (new)
zip 100 black (new)
SB Live
Creativ 5.1 Speakers
Tall Texan
Postby imtim83 on Mon Jan 27, 2003 4:23 pm
Tall Texan cool. I certainly wish i could test out two cd-rw drives burning at once but my first one doesn't have burn proof. :( Oh well. I just love testing things. Heck i wish i could test 4 or 6 + different cd-rw drives all writing at the same time! That would be cool!
Please Reply
imtim83
Postby Tall Texan on Mon Jan 27, 2003 4:35 pm
imtim83 wrote:Tall Texan cool. I certainly wish i could test out two cd-rw drives burning at once but my first one doesn't have burn proof. :( Oh well. I just love testing things. Heck i wish i could test 4 or 6 + different cd-rw drives all writing at the same time! That would be cool!
i think my next test is gona be to add an old hp 9100series 8x4x32 i have on a shelf to it and see if i can do three i know the hp does not have burn proof so i will let you know how it goes
AMD XP - 1900
1 gig DDR
80 gig WD 7200 x 2
zip 100 black (new)
SB Live
Tall Texan
Postby imtim83 on Mon Jan 27, 2003 4:56 pm
Cool Tall Texan i have a old hp 9100 series 8x4x32 too. Its a HP 9110i 8x 4x 32x but i bought a plextor 24x 12x 40x a while back. I never tried burning two cds at once sense i know my HP 9110i 8x 4x 32x cd-rw will have a buffer underrun error if i try i bet. Then again i may beable to do 2 cd-rw cds! Not sure if cd-rw cds can get buffer underuns. Hmm.
Please Reply
imtim83
Postby Tall Texan on Mon Jan 27, 2003 6:38 pm
imtim83 wrote:Cool Tall Texan i have a old hp 9100 series 8x4x32 too. Its a HP 9110i 8x 4x 32x but i bought a plextor 24x 12x 40x a while back. I never tried burning two cds at once sense i know my HP 9110i 8x 4x 32x cd-rw will have a buffer underrun error if i try i bet. Then again i may beable to do 2 cd-rw cds! Not sure if cd-rw cds can get buffer underuns. Hmm.
ok it did not work with the hp. sorry dude i tried. but im fixen to try something else :P i just bought another sw-240 gona see if i can do three that way. got an ata 100 pci card also so i can run everything on its own chn. wish me luck
AMD XP - 1900
1 gig DDR
80 gig WD 7200 x 2
zip 100 black (new)
SB Live
Tall Texan
Postby ryus on Mon Jan 27, 2003 8:34 pm
About the TDK 52x24x48 being a Lite-On, I'm not too sure if it is. Because on the box, it specifically says "Buffer Under Run Protection", and if I'm not mistaken, isnt that a Sanyo chipset???
Liteon uses Smart Burn.
P4 3.0C, Abit IC7-MAX3, Antec True480W, Kingwin Aluminum case, 2X256 OCZ PC4000 Gold Edition,
Maxtor SATA 160GB, Maxtor 40GB ATA133
ATI 128mb Radeon 9800 Pro
Asus CD-S520, LiteON JLMS 166, Plexwriter48/24/48A, Pioneer 107
ryus
Postby dhc014 on Mon Jan 27, 2003 8:55 pm
The TDK 52x24x48 (5200B) is a Lite-ON. I am 100% sure. Buffer Underrun Protection is the generic name for any type of Buffer Underrun Prevention technology.
dhc014
Postby Ian on Mon Jan 27, 2003 9:19 pm
It's a Lite-On.
Postby dodecahedron on Tue Jan 28, 2003 2:05 am
ryus wrote:About the TDK 52x24x48 being a Lite-On, I'm not too sure if it is. Because on the box, it specifically says "Buffer Under Run Protection", and if I'm not mistaken, isnt that a Sanyo chipset???
the Sanyo buffer underrun protection technology is called BURN-Proof.
Postby ryus on Sun Feb 02, 2003 4:09 am
Actually I saw this drive (52x24x48) with "BurnProof" on the box.
Also, with the recent article about TDK's 2nd edition drive, it also sports "BurnProof". This new drive is definitely not a Lite-On, and maybe the 52x24x48 might be the same brand , Asus maybe??
ryus
Postby dhc014 on Sun Feb 02, 2003 4:26 am
Like I said before:
dhc014 wrote:The TDK 52x24x48 (5200B) is a Lite-ON. I am 100% sure.
There is no other 52x drive from TDK right now.
dhc014
