killed my mother board?
Postby kaga on Tue Mar 11, 2003 3:39 am
ok i got my AMD XP 2200 when i try to install it i had a hard time puting the heat sink in and my screw driver hit some part of the mobo. now i have problems with the boot when i turn on the computer i get no video signal and when i try to turn off the power i can't have to do it from the power supply. did i killed it ?
Coming Soon Sager NP2090
Intel® Core™2 Duo T7500 2.2GHz
nVIDIA GeForce 8600 GT w/512MB
2GB DDR2/667 Dual Channel Memory
100GB SATA/150 7,200 RPM
Dell Inspiron 6000
kaga
Postby BuddhaTB on Tue Mar 11, 2003 3:51 am
I would check all of your cable connectors and jumpers on the motherboard before jumping to the conclusion that your motherboard might be dead. Make sure they are set correctly and the connections are tight. Also check to make sure the video card is all the way into the agp slot if you don't have onboard video.
What's the make and model of your motherboard?
BuddhaTB
Postby aviationwiz on Tue Mar 11, 2003 8:34 am
GA-7VRXP
Look in his sig.
Postby dimitri on Tue Mar 11, 2003 2:11 pm
Did you kill your mobo? Sounds like you injured it. If it was dead you wouldn't get it to run at all.
It's a very common mishap. You should look for the acrewdriver scratch and examine it with a magnifying glas. If you see any shiny metal color in it, you've damaged a lead. It usually can be repaired by professionals. Ask your vendor.
All the best, dimitri (a.k.a digi, mango)
digi.rpc1.org | digidvd.tk
LiteOn/Jlms dvd drives: info, firmware, regional freedom :cool:
dimitri
Postby CignaXI on Tue Mar 11, 2003 6:20 pm
I have your same problem with my mobo, I recently purchased a XP 2100+, I sent it back to replace it and they sent me a model 8 (0.13 microns) version. My ECS K7VTA3 v2.x supports model 6 (0.15 microns) but the model 8 not. I don't get video signal and my keyboard's num lock key doesn't work. You should go to amd's site and check if your mobo supports your cpu:
http://www.amd.com/us-en/Processors/Pro ... 8_756_3734^4348^7923,00.html
You should also check your power supply, sometimes the psu doesn't provides enough mA to support the CPU.
PS: copy/paste the link don't click it.
CignaXI
Postby kaga on Tue Mar 11, 2003 8:13 pm
but then i swap back my Tbird 1.1Ghz and still the same thing
Dell Inspiron 6000
kaga
Postby kaga on Tue Mar 11, 2003 8:16 pm
i think i probal scrath it any one know where can i get it fix?
Dell Inspiron 6000
kaga
Postby dimitri on Wed Mar 12, 2003 1:56 pm
kaga wrote:i think i probal scrath it any one know where can i get it fix?
I think you better say where you are mate, I suspect an address in Lapland might not suite you :D
Usually the place you bought it can arrange it for you, or at least give you the address.
dimitri
Postby CignaXI on Wed Mar 12, 2003 2:49 pm
Good Luck Kaga!
CignaXI
