Problem with DVD burning and Nec 3500
Postby SbH on Thu Sep 16, 2004 5:55 pm
Hi there !
As you can read in the subject, my problem is quite simple.
I have a Nec 3500 and certified x8 DVD-r (brand is medianca) and i can't burn at more than x4 with DVD Decrypter.
That's pretty nasty since while it's bruning at 'max' (~x4) speed, it does a lot of buffer lose.
Do someone have experienced the same problem ? Any idea ? Thanks in advance for your suggestions or solutions !
(UDMA is on on source (western digital 200gb, 8mb cache) & dvdr device)
cheers !
SbH
Postby Wesociety on Thu Sep 16, 2004 8:49 pm
What's the MID code?
What version of Decrypter are you running?
