Problem with Liteon ltr-48125w
Postby achancha on Fri Jan 10, 2003 4:24 am
I have a problem with Liteon drive. It worked fine before but now it can't write any cd-r media. It can read cd-rom and can write cd-rw with Mt. Rainier format.
I use Nero to write my cd and it will stop at around 4-7 % of writing process depending on media size.
Anyone know how to fix this problem?
Thank you,
achancha
Postby hoxlund on Fri Jan 10, 2003 1:21 pm
are all your hard drive's defragged? and scandisked?
and make sure DMA is enabled
Postby achancha on Fri Jan 10, 2003 2:35 pm
I have DMA enabled ,scan and defrag all my drives but I still can't get it to work. Any idea?
achancha
Postby hoxlund on Fri Jan 10, 2003 3:15 pm
what firmware is the lite-on, is motherboard's bios up to date, are there any other devices on this ide chain
Postby achancha on Fri Jan 10, 2003 5:46 pm
I have the lastest firmware for my burner and my mainboard is AT7-Max2 with Athlon XP 2200+, ATI AIW Radeon with latest driver. My burner is set as master on secondary ide with no other devices.
achancha
Postby hoxlund on Fri Jan 10, 2003 6:36 pm
hmm i think you exhausted all my advice, where did you buy it from?
Re: Problem with Liteon ltr-48125w
Postby dhc014 on Fri Jan 10, 2003 8:14 pm
achancha wrote:I have a problem with Liteon drive. It worked fine before but now it can't write any cd-r media. It can read cd-rom and can write cd-rw with Mt. Rainier format.
Thank you,
Maybe you're using bad media, or you're writing too fast.
dhc014
Postby hoxlund on Fri Jan 10, 2003 8:28 pm
i doubt writing to fast, but bad media maybe, i use memorex toyo yuiden or whatever there called, 48x, 100 spindle
