Samsung 352B Problems
Postby govern1 on Mon Sep 29, 2003 8:45 am
I've read around here that there are problems with this drive. Well, I never noticed it at first, but I do now. Reading cd's works just fine, but burning is another story. Whenever I burn a cd, about half way through, the burning speed slows way down for about 10 seconds, then speeds back up. When it finishes, I get a warning that an underburn was avoided two times. I've tried every different firmware available, no change. I put my 348B dirve in and do not see that problem, it burns flawlessly.
What gives? Is there any fix for this (other than a new drive)? Is Samsung aware? (Using Nero 6, btw and the 8 meg retail version of the drive)
Shawn
edited for spelling
govern1
Postby vsekh on Mon Sep 29, 2003 9:16 am
What brand of CD-R media are you using?
I have the same problem you do on most media that it tries to burn at 52x speed.
vsekh
Postby govern1 on Mon Sep 29, 2003 12:27 pm
All brands. Plus, it never tries to burn at 52x, it always says the media I'm using is only 48x certified and downgrades the burn speed to 48x. I use Verbatim, Imation and Fuji.
govern1
Postby vsekh on Mon Sep 29, 2003 1:02 pm
I have used those media you listed. I can only select 48x speed before I start the burn.
Memorex 52x Prodisc media, which I got from COMPusa, is the only one that I can sometimes get a full 52x burn without the burner slowing down. I was not able to find any other media that will burn successfully all the way through reaching 52x speed.
I have tried all the firmware available upto T806.
vsekh
