Siig PCI IDE controller card & optical drives
Postby dodecahedron on Tue Dec 14, 2004 12:10 pm
i'm thinking of getting a PCI IDE controller card, so i can move the HDs to it and free both mobo's IDE ports for optical drives.
i was curious if anyone has any experience with running optical drives off such an IDE card.
i know it's generally not recommended, but i've heard (i think) that Siig cards are better than Promise in this respect.
Siig
Postby shaun on Mon Dec 20, 2004 8:23 pm
http://www.siig.com/product.asp?pid=437 is the card that I have had the most success with.
Promise + burning = headaches (reading is fine, but burning over 16x on a CDRW was troublesome)
"Traveling through hyperspace ain't like dusting crops, boy"
shaun
CD-RW PiMP
Re: Siig
Postby dodecahedron on Mon Dec 20, 2004 8:25 pm
shaun wrote:http://www.siig.com/product.asp?pid=437 is the card that I have had the most success with.
thanks for the link.
do you have a recommendation on an external case? (from the other topic)
BTW, welcome to CDRLabs :D
Postby shaun on Mon Dec 20, 2004 8:33 pm
Glad I could help :) I have been lurking for a long time, but now I am going to try and help out around here a bit and do some hardware reviews to take the pressure of Ian, and help out in the forums the best that I can.
As for cases, I am partial to Kingwin aluminum enclosures (I have used several...not sure if I like the new "pimped out" ones or not), The aluminum helps keep the drives cool...and there are models that support USB2 and Firewire. ( http://www.kingwin.com/pdut_detail.asp? ... =27&ID=182 )
Bytecc are cheaper, but still good enclosures too ( http://www.byteccusa.com/product/enclosure/ME-340.htm )
shaun
CD-RW PiMP
Re: Thanks
Postby dodecahedron on Mon Dec 20, 2004 8:53 pm
shaun wrote:Glad I could help :) I have been lurking for a long time, but now I am going to try and help out around here a bit and do some hardware reviews to take the pressure of Ian, and help out in the forums the best that I can.
WOW! we have a PiMP on board!
i just now noticed (when i read you're gonna do hardware reviews)! :D
great news. :P
Postby dodecahedron on Mon Dec 20, 2004 8:57 pm
thanks for the 2nd link! (kingwin)
i've been contemplating an external case for a while now.
finding a combo case (FireWire + USB) that uses the Cypress chipset for the FireWire part isn't easy. i don't think i saw kingwin before.
this look interesting:
http://www.kingwin.com/pdut_detail.asp? ... =27&ID=179
i agree, it looks a bit gaudy!
now gotta find out how much it costs!
OK $53 at newegg...not too bad.
the Bytecc one looks nicer IMO
but i think it uses the Prolific chipset, alas.
Postby shaun on Tue Dec 21, 2004 10:50 am
Living in Canada, the cheapest I could find for the Kingwin was $85 Cdn (http://www.canadacomputers.com/storage.html)...so with the exchange rate being the way it is, the Newegg price is very good :)
shaun
CD-RW PiMP
