Sony DU-18A dvd burner ?
Postby dellboy on Mon May 17, 2004 5:46 pm
hi,
please can anybody help please, is the sony burner mentioned above,
the oem version of the sony dru- 530A retail model, and is all
the spec the same. also where would i get the latest firmware for the
oem model as its not mentioned on the sony site.
is this a burner worth buying
dellboy
Postby Kennyshin on Mon May 17, 2004 6:14 pm
There are DW-18A and DU-18A. DW-18A is a Sony OEM model for DRU-530A and DU-18A is OEM model of DRU-700A.
Kennyshin
Postby dhc014 on Mon May 17, 2004 7:44 pm
I have never heard of a DU-18A, are you sure that it is not a typo?
Sony DW-U10A = Sony DRU-500A
Sony DW-U12A = Sony DRU-500AX
Sony DW-U14A = Sony DRU-510A
Sony DW-U18A = Liteon SOHW-812S
Sony DW-D18A = Liteon SOHW-832S
dhc014
Postby code65536 on Tue May 18, 2004 1:55 pm
klumy wrote:no it'S not a typo
It is. The site says DWU-18A when it should be DW-U18A. As dhc014 said above, this is a rebranded LiteOn 812S.
code65536
